8
The computer get's its signal from the rear speed sensor on the tail shaft. I'm assuming they changed the tranny fluid........however I would recommend you double check the tranny fluid level, and color/smell to make sure it's new. you could also ask them if they replaced the fluid, since it's not 100% necessary when you take the rear tail housing off.
This is something that pretty much every dealership will do.....they're going to placard their names all over the car if they can......the majority of the drones in the US don't care or don't even know it's there. However, yes the few of us that actually care about our cars get upset at this. More then likely the lot attendent was told to not touch the rear plate/surround.....which he didn't.....however most lot attendents are younger, and are told to put those plates on everything.....so he/she was just doing what he was told..... Glad to hear they're trying to make it right though....
Just to let you know......there is not two tranny mounts, there is only one, and it's located at the rear of the tranny at the rear crossmember. I don't want to point fingers, but if heard a mechanic say they replaced two tranny mounts, when there's only one.....i'd be a little suspicious of their work. Either they're not competent to know what part is what, or they are trying to screw ya. Just my two cents.....
Is it an ej20 n/a or turbo motor? I haven't really heard too many problems about the ej20 motors. Nothing like what we have heard about the 2.5. I do hear ya on the maintenance. It's one thing after another. I've got a couple more things I need to do to mine, and I think I'll see the light at the end of the tunnel.....until something else breaks or needs replacing.
Definitely get a 4-wire. 3-wire sucks. I actually just replaced my 3-wire OEM with a 4-wire generic from oxygensensors.com. I would highly recommend you go that route, or replace it with an OEM O2 sensor. Whatever you do, make sure you keep the 4-wire sensor. I put it in last night, and I don't think my car has ever idled as good as it does now. I didn't try and measure the potential difference between where the O2 sensor mounts and a good ground point, but considering the bolts to the heads & the bracket on the back of the tranny are pretty much it in terms of completing the grounding circuit. I know all of my exhaust is rusted to hell, including the head bolts. The only & last option I would consider is getting an additional wire and clamp it to the body of the O2 sensor & then run that to the extra ground wire. But it sounds like they sent you the wrong part, so just send it back for the correct part. Also, at least for my car, the stupid generic instructions they had for the wiring was pretty much incorrect for my car. I used the pin-outs in my FSM to know what wires to connect to what.
CV Joint Boots
Legacy777 replied to a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I actually just ordered a set of axles from cvaxles.com Should've done this in the first place rather then repack the bearing & replace boot. Cost was $55 per axle & $50 core charge. Not bad in my mind, and they also have a lifetime warranty on them. -
ATF spec
Legacy777 replied to patcal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
There is a reason it says they are compatible....it's because they are. It may not be best practice to do so. The boiling point temps really won't mean squat is one thing. Dot 3, Dot 4, & Dot 5.1 are compatible and can be mixed. I wouldn't recommend mixing all those, but they can be mixed. Dot 5 is the silicone based brake fluid and it CAN NOT be mixed with Dot 3, Dot 4, & Dot 5.1. It's also not recommended for street use since it does not absorb water. -
ATF spec
If you want to get technical, dextron III supercedes dextron II.....just like part #'s
