8
the autos do have low end grunt.....I'd suspect some sort of problem... but to answer your question, read this on the tranny swap http://www.legacycentral.org/library/transmission/convert.htm you didn't mention what year/model legacy you have, but without knowing too much about your legacy, I'd say there's 99.9% chance the WRX tranny will not have the same final drive ratio as your legacy. So....you would need a new rear diff as well. Other solution would be to find a tranny that has the same gearing so you don't have to swap rear diffs.
why not just pull the codes and verify it what code is in there. My car has been doing something very similar, and I too have just replaced the starter contacts. I've also just replaced cam & crank sensors, ignition is about the only thing left I can think of.....or possibly an ECU. But it's very sporadic as to when it does it. There's only been one time where it wouldn't start for a good 5-10 min......and of course that was when I had to go to the airport to go out of town.....grrr I'd be interested in some test procedure to verify the ignition or some other componant.
The brakes consist of a caliper and a bracket that mounts them to the hub. There is a bolt that holds the caliper to the bracket. It is on the bottom of the caliper. There is a top pin that the caliper slides on. The combination of these two provide the "floating" caliper design. If these pins don't move "float" any more then the calipers will stick and you get problems. Some times they can be cleaned and re-greased. Re, the pulsing in the pedal or steering wheel. Pulsing in the steering wheel, it's most likely front brakes. If you get pulsing in the pedal, it's most likely the rear brakes.
check your caliper guide pins......if they move freely, sand down the pads and rotors slightly and then go rebed the brakes back. Go make several (10) or so stops from 60-15mph with medium/heavy brake pressure. Do them pretty much back to back. After the last one, drive slowly around and don't use the brakes, allow the rotors to cool down.
Spark plug changing, 90 Loyale w/ AC
Legacy777 replied to brus brother's topic in Old Gen.: 80's GL/DL/XT/Loyales...
this is more suited in the old gen forum
