8
Welcome to the USMB!
Brake cables
Legacy777 replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Best suggestion would be to try and find used ones. You can try posting in the marketplace. If you want new ones, you'll probably have to go the dealer. -
new to the forum not new to subaru
Legacy777 replied to sikend667's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the USMB. -
Hey all from Auburn Wa.
Legacy777 replied to 01SF5's topic in Meet n' Greet. Your USMB Welcome Center
I don't know if I'd say it's typical, but it certain sounds like a fueling issue, which can be related back to the coolant temp sensor. They're about $20 from one of the online subaru dealers www.subaruparts.com www.subarugenuineparts.com or www.1stsubaruparts.com All of those dealers are in the PNW area, so you may be able to pick it up and save on shipping. -
Welcome to the USMB. Sometimes cold starting issues on these subaru motors can be caused by a worn coolant temp sensor. There are a lot of engine temperature related fuel trim tables, so if that sensor is reading wrong when cold, that could be causing your cold start issues. -
Actually, that NAPA one looks pretty similar to the Subaru t-stat. Here are some pictures. http://www.experiencetherave.com/subaru/images/ej22t/10/DCP_4799.JPG http://www.experiencetherave.com/subaru/images/ej22t/10/DCP_4800.JPG http://www.experiencetherave.com/subaru/images/ej22t/10/DCP_4801.JPG http://www.experiencetherave.com/subaru/images/ej22t/10/DCP_4802.JPG http://www.experiencetherave.com/subaru/images/ej22t/10/DCP_4803.JPG http://www.experiencetherave.com/subaru/images/ej22t/10/DCP_4804.JPG http://www.experiencetherave.com/subaru/images/ej22t/10/DCP_4805.JPG
Yes, that is absolutely 100% true! If you don't have an OEM Subaru thermostat in there, it will give you problems. Stant also makes the "Xactstat", which is supposed to be the same as an OEM Subaru thermostat. I have not used the Stant Xactstat, but this thread has more info. http://www.ultimatesubaru.org/forum/topic/124587-new-stant-xactstat-oem-thermostat-available-at-parts-stores/ The cost looks to be similar to an OEM Subaru t-stat, so it's kind of up to you whether you want to give the xactstat a try.
Well hopefully they find something else or if it is the headgasket it just goes so you can replace it and get it fixed.
New Guy from Western Maryland
Legacy777 replied to JackOfAllTradesRuss's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the USMB!- 1 reply
- 1
Welcome to the USMB. If you have a check engine light on, you're on the right track to try and figure out what codes are stored. I am pretty sure that your car should be OBD2 compliant, and if it is you should be able to read the codes with a standard code reader. Here in the states, local autoparts stores will read the codes for free. You could try this and see what codes come up. I'd then suggest pulling the battery for an hour or so to clear the codes, drive the car and then pull the codes again to see what comes back. That should eliminate any false or old codes.
Welcome to the USMB. That sucks about the head gasket. I'm sure there is a service limit on the heads in how much they can be machined, but I don't know the amount. It would be in the factory manuals. A machine shop that deals with Subarus would likely have that info. Or you could try calling and talking with a local Subaru dealer.
