8
Foresters need love too...
Legacy777 replied to riceman's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the USMB Chris! I think the first gen Legacies were some of the best designed & built subarus. I've heard similar stories from folks that pick up a first gen Legacy for a reasonable price and then they end up sticking with Subarus. The first gen Legacy, a gateway Subaru -
Tom, Welcome to the USMB! I drive past Mahwah somewhat frequently when I fly into Newark and drive to PA for business. I think the GPS pronounces the name incorrectly.....but I guess that's why I remembered it
Welcome to the USMB. Clutch shudder can be caused by several things including driving style. However one of the mechanical things that can cause it is a worn snout on the transmission. The throw out bearing rides on this and if it's worn or grooved it can allow the clutch to not be in the proper alignment. This kit was made to help solve the problem. http://www.pdmusa.com/
New owner in Vancouver BC..
Legacy777 replied to 007Noobaru's topic in Meet n' Greet. Your USMB Welcome Center
Brent, Welcome to the USMB! -
No, they are not easily interchangeable. I believe the fuel rails are different as well. You can use the newer red top injectors, but would need to swap the rails and ECU. Some of the pins are slightly different as well, so the easiest thing is to just use the injectors meant for the 90-91 auto trans legacies.
I moved your post to the new gen forum. P0420 is related to the rear O2 sensor and catalyst inefficiency. These codes can sometimes pop up for random reasons. I'd recommend taking it to an auto parts store that will check/verify the code and reset the ECU. If the code comes back, your rear O2 sensor could be bad or something to do with the wiring.
Welcome to the USMB! It sounds like you've done quite a bit of work on your Forester!
new owner of a 1988 gl wagon (OREGON)
Legacy777 replied to SHOBER's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the USMB. Here's a thread that talks about how to share photos. http://www.ultimatesubaru.org/forum/topic/152891-recurrent-question-how-to-share-photos-on-your-posts/ -
Welcome to the USMB Neil. On the lift gate struts there is sometimes a little clip that goes around the metal ball that the strut connects to. If you remove that clip it typically allows you to remove the strut. I'd suggest posting in the new gem forum as there may be other outback owners that can help.
Kia Sephia Sporty
Legacy777 replied to Loyale 2.7 Turbo's topic in Non Soob Cars and Bikes Discussion
Glad to hear that the new fuel pump assembly fixed the starting issues, that's good news -
Proud new dad of a 1985 Station Wagon GL
Legacy777 replied to ElGarzita's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the USMB! I'd recommend posting in the 80's forum about the clunking noise. -
Greetings; I am a new member
Legacy777 replied to troytet3's topic in Meet n' Greet. Your USMB Welcome Center
Welcome and glad to hear you're loving the subie! -
Hello from Surrey BC
Legacy777 replied to flounder's topic in Meet n' Greet. Your USMB Welcome Center
Greetings from the Olympic Peninsula
Legacy777 replied to JeSuisSubie's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the USMB and glad to hear it's been helpful for you! -
Hello from Hilton Head....
Legacy777 replied to Bigborgel's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the USMB! I think the newer Subies (2015) are a bit lighter than the previous generation. Enjoy the new subies! -
Hey From Washington
Legacy777 replied to Sergeant Major's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the USMB and hope you enjoy the Outback! -
