90
silly question, but did you turn the heat selector to hot when you were filling the system so that the heater core is getting filled/burped as well???? "swirling" sound under the dash says heater core to me....
Overkill on a CEL question
heartless replied to The FNG's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yeah, there are some minor missing details trying to pull the details out of my memory here - been a couple years since i messed with the EA82's... first - neither set should be plugged in for normal everyday use. Now, if i recall correctly, the green are the read memory, white is the self diagnostic (i wont swear to this, it has been a while, and someone else may correct me on this) best way to check for codes is: connect ONE set of connectors - check for codes switch connectors (unplug first set, plug second set) check for codes again. (Make note of what color plugs are being used for which codes you get) when all else fails, you can clear codes by disconnecting the battery overnight. seriously tho, by doing that you would have a fresh view of what is happening with your car. BTW - your pic is "engine side of firewall on drivers side" "engine side of firewall" = under the hood, "drivers side" = left side of car as sitting in the drivers seat. "firewall" = the "wall" separating engine compartment from passenger compartment. -
there is a full write up in the USRM that will tell you how to read, diagnose and clear codes on these cars... under "engine electrical", page 2, "Subaru ECU codes for 1983-1988" (also applies to the Loyale models) -
Thanks Kara - sorry to hear about the dream that is weird! and happy belated anniversary!
yeah, um, how do i say this...not gonna happen that way...the spring compressors are too large to fit up into the space near the tophats...you wont be able to get them far enough up the spring to be able to compress them enough to change the strut. this is especially true of the rears. Have the HF spring compressors here and have used them several times (multiple Subarus here) not the greatest quality of materials, but they WILL get the job done, Oil the threads to make it go easier - I dont recommend using impact tools on these - that tends to eat up the threads (yeah, been there, done that) having an extra pair of hands can be useful on this job btw...not necessary, but useful.
ok, when did you crawl underneath my car??? seriously - mine looked that bad too (actually, still does, havent cleaned it yet, but the leaks have been stopped) Lots of "small" leaks add up to a very ugly mess under these cars. in mine's case, it was cam covers, oil pan, oil pump, and oil seperator plate on the back - leaks were so bad that the back end of my car (as in the lift gate & back glass) had an oily/dirty film on it.... motor got pulled almost 2 months ago and got a reseal & timing job done, and got stuffed back in all in one day - actually, one afternoon. now, when i stop at the gas station it is fill the tank & check the oil, instead of check the tank and fill the oil... grab a couple cans of Engine Brite, hit the local carwash and clean things up as best you can, then keep a close eye on things to determine where your leaks are coming from.
no. much too sad...
:( i wanna bawl my eyes out!! my baby will be leaving me tomorrow. :(
changing doors and have a quick question
heartless replied to firstsubi's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yup, sometimes that can make all the difference. -
according to my 1990 FSM - this is a correct diagnosis. "Trouble code 45: Atmospheric Pressure Sensor When trouble code 45 appears on display, replace ECU" I would think that any FWD automatic ECU from 90-94 should take care of it for you. sorry i cant give you an exact part number, my car is an AWD...
both O2 and knock sensor can cause serious running issues like you are experiencing. fairtax has pointed you to an excellent article on the knock sensor. too bad there isnt one as good about the O2 sensor... General rule of thumb is to start with the smallest number code and work your way up. In this case, replace both O2 and knock sensors and see how it goes.
88 gl10 died, and wont start again
heartless replied to danzick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
glad to hear that swapping the injector housing seems to have fixed it for you. neither set of test plugs should be plugged in for normal daily driving. make sure your codes are cleared, either via the proper procedure as outlined in the USRM article, or by disconnecting the battery for several hours, and happy driving. by clearing codes, you will know you are looking at a "new" problem next time the light comes on, not the old one you have already fixed. -
Clue number one - Check engine light is on - GET THE CODES READ!!!! Sorry, but the CEL will NOT come on for no reason - if it is on, there is a reason for it - find out that reason and fix the problem - duh. most of the large chain auto parts places can usually read the codes for you for free (places like advance auto, autozone, etc)
