90
interesting... my "quality" comment was meant more for the 1/2 drive stuff than the 3/4, lol like i said.. i have an extra long 1/2 breaker that i keep in the car (w/19mm socket) for lug nuts.. the head of that bar is FAR beefier than the standard breakers. I would not hesitate to put a nice long cheater pipe on that bad boy and have done so.. i forget exactly what we were doing... axle nut, maybe... but yeah, 5-6 foot cheater and other half basically bouncing on the end of that and it showed no signs of giving way.. the nut, however, did break free... and when it was all said and done, the cheater was bent, LOL would never attempt a cheater that long on a standard 1/2" breaker...
If you can find one, a lower mileage '95 Ej22 is the way to go, engine wise. Non-interference, so no major damage if a timing belt lets go. Also stupid easy to work on with basic tools... but as GD said, it will be under-powered for what you are wanting to do. beyond that, best I can offer is to make sure ALL maintenance is up to date. Fluids, brakes, cooling system, and so on. I get the sentimentality of keeping the car, but in all honesty, I would fix it up for a daily driver, and get something else more suited for the offroad adventures. Can you go "offroad" with it? yes. Are they fun to do a little mild offroading with? most definitely, but as mentioned, will not be nearly as capable as the vehicles mentioned by GD.
- 4 replies
- 1
- battlewagon
- outback
(and 3 more)
Tagged with:
the "quality" of the tool has a lot to do with things, too... lets not forget that. we do have some 3/4 drive stuff here, but not a lot.. one set that was purchased to do a hub on a Dodge truck.. go figure, LOL we have several 1/2 breaker bars here.. including an extra long, heavy duty one purchase from HF.. i love that one.. being female, the extra leverage is a wonderful thing, @jonathan909 does Canada use the salt or brine on the roads up there? Here in WI we get both.. depending on the situation... the spray the brine before a storm, and use salt after if things get icy. makes for some interesting times dealing with under the car stuff.
and not many have 3/4 drive at their disposal. just sayin.. @ThosL - there is a product called "Freeze Off" - not exactly cheap, but it does work more often than not.. read and follow the directions on the can carefully and you could have success. Living in Wisconsin, I know the pain of rusted fasteners.. Freeze Off has saved our butts more than once when working on the older, rusty vehicles.
i am assuming by this comment that it has a current headgasket issue? If yes, making sure that job is done right is job number 1. There is a specific gasket recommended for this job.. part number ends in 770, i think... a search should turn that up.. look for info from user General Disorder... also do the FULL timing job... belt, water pump, all idler pulleys, new oil seals behind the cam & crank pulleys.. and tensioner, if warranted. And do NOT use a Gates kit - their quality has dropped dramatically. Aisin is the best option. A search of this forum will give you lots of information on that job. not a lot of "upgrades" available for these cars in general, but there are few items... King Springs is one that comes to mind that would be ideal for you. not cheap, but well made. There are some smaller lift kits available with a bit of searching.. nothing extreme, but moderate. OEM axles are still the best available - aftermarkets have a much higher failure rate... reboot & regrease of the OEM axles will provide better longevity. I know others will have more info.. so be patient..
- 4 replies
- 2
- battlewagon
- outback
(and 3 more)
Tagged with:
honestly.. sounds like someone just likes to stir the pot.. If it was an ongoing issue with new cars, then maybe i could see the idea of a CAS - but the vehicles in question are OLD! Some over 20 yrs old. My 2002 Forester, with nearly 270K miles, will be 20 yrs old next year - if the headgasket were to fail at this point, do I really have a case for a lawsuit? Short answer, No, i do not, for multiple reasons, not the least of which is age. And as others have said.. in general, not really any worse with Subaru than with other manufacturers... At least my Subaru is not going to explode if I get rear-ended... LOL
no problem Bennie. and to be very honest, i did it as much for myself as for anyone else, lol trying to get my brain to think in metric terms a bit more... I have several 3d printers, so working in the smaller sizes is becoming old hat, but those longer ones.. yeah.. hard for me to go from millimeters to kilometers yet, or even meters, lol.
Well said, GD! for me.. with a job this complicated, I would gladly pay someone like GD to do the job for me and know it was done right. Do I have the skill set? yeah, maybe... the tools? most likely... the time? most definitely. but, there are things about this job that I feel are worth paying someone (that is competent) to do it for me.
yeah, shop prices are going to vary dramatically depending on location. East coast, or major metropolitan area, yeah.. $2500-3500 is probably a good estimate. Rural midwest, it might be a little lower, but probably not by a lot. head gaskets are a major job.. just to pull the heads is going to take time - ie: labor.. intake has to come off, various things disconnected, moved out of the way.. then clean up of old gaskets, inspection to make sure everything is ok.. head work to make sure it is flat/not warped.. valves inspected, possibly lapped while the head is out if needed.. lots of work for the job means lots of labor and at going shop rates ($80-100/hr around here), it adds up quickly.
22mm i believe is the minimum thickness... at least that is what the FSM says for my 2002 Forester, with similar specs for a 16" wheeled 2006 Outback... the 17" wheeled version has slightly larger specs, so I would suggest checking the FSM for your vehicle per the 2002 Forester FSM... Standard value - 24mm (0.945in) Service limit - 22mm (0.866in)
