90
Personally, I would add the 95 Legacy to that list. Just a tiny little bit roomier than the earlier ones, but the interior (mainly seats) was not quite as nice as the '90 LS.. (altho the LS seats did swap in pretty nicely ) Still has that non-interference EJ22 that is so easy to work on. I still miss my 95 Lego with the Forester strut lift & the '90 LS front seats.. Don't get me wrong, the 02 Forester is nice, but yeah, miss my Lego
Aside from parts directly from Subaru - KYB struts all the way. None of the other aftermarkets are worth messing around with, imho. Too soft/mushy KYB top mounts are of good quality as well - would not even bother with any others for that, either. Have used them on multiple vehicles over the years with no problems at all For me, RockAuto is just "easy" - Even local parts stores have to order stuff for Subarus because they are not common enough in this area for them to keep things in stock (unless it is something that is common to other brands as well, like brake pads), and generally speaking, the local stores charge more than what I pay at RA, even with shipping costs. (yes, I cost compare before actually buying) Example - From my local Advance Auto... as you can see, I can't even get them at my local store... From Rock Auto... Advance is nearly twice the price for the exact same part - before we even get to shipping.. for both rear struts and shipping from RA, I spent $136.70 and they were delivered to my door - today.
No, none of that is necessary. just replace the PCV valve and call it a day
- 4 replies
- smoking
- oil consumption
(and 1 more)
Tagged with:
side mirrors are pretty easy to replace. Look here for FSM (Factory Service Manual): http://jdmfsm.info/Auto/Japan/Subaru/ I am not familiar with the newer models, but all of the ones I have been around (late 80s to 2006) there is a trim panel on the inside that pops off to expose the nuts that secure the mirror to the door. Most likely will need to pop the door panel loose to access the wiring harness connectors, but that is not usually all that difficult either. Just take your time so you don't break anything
the big difference is going to be in weight of the car - with the wagon being heavier - more glass and roof the sedan struts might work for a while, but will possibly give your car a "saggy butt" appearance and most likely wear out faster. Rockauto has the correct ones for the wagon.. https://www.rockauto.com/en/catalog/subaru,2005,legacy,2.5l+h4,1430732,suspension,strut+/+coil+spring+/+mount+assembly,15174
Texan - Changing out the propshaft would kind of preclude that issue... how old are the struts? just did fronts on my 02 forester - they were so bad that I had a TERRIBLE vibration -most pronounced on left front - the wheel was "bouncing" (commonly seen on minivans, usually in the rear...) About to do rear struts as well, but had to wait for funds availability or they all would have been done at the same time. Point is, after changing the struts, the vibration is gone.
for "other makes and models" are the key words here. there is no such readily available creature for a Subaru. to the OP - you could take the time to research part numbers for a newer model that does have brand name quick struts available - compare bare strut to bare strut and see if the part numbers are the same. If they are, then you could possibly use assemblies for a newer vehicle than yours. But the fact remains, for your specific year, there is no quick strut available, nor is there a "strut delete" option available
very few full strut assemblies (what you call "quick struts") are available for the older Subarus - you are dealing with a 22 yr old vehicle here - and usually only Monroe, which tend to be rather soft. I just put new front struts under my 2002 Forester today. I could have gotten the Monroe assemblies, but I don't like the ride of those. I prefer the feel of KYB struts and there are no assemblies made with those available for this vehicle. compressing the spring is not that terrible, if you take the appropriate precautions - most kits have a safety catch, use it, take your time, and work both sides evenly. you can either buy a spring compressor kit or possibly rent one. One word of caution - either way do NOT use power tools on the bolt type! You will destroy the threads on the bolts. we have done struts often enough (multiple vehicles) that we purchased one of the hydraulic spring compressors from horrible freight. honestly, i don't recommend it, lol. it does work, but getting things to line up correctly when installing the new strut can be a bit of a headache. the only other option is create your own "quick strut" assembly by purchasing all new parts - strut, spring, top mounts, etc - and putting everything together before you start pulling the old ones out of the car.. either way, you are going to have to compress a spring, and you will want to get new front mounts at the very least. My car is several years newer than yours and mine were completely shot - the grease was coming out of the bearing, and you could actually see the balls inside. or, you pay someone else to do it for you. Your choice.
is it brand new OEM or aftermarket new? Yes, it does make a difference. Most parts store alternators are not "new" - they are remanufactured - and have a high failure rate within the first year. If it is a parts store unit with any kind of warranty - take it back, get your money back (as much as they will give you) and invest in an OEM unit - even a used OEM one from a junkyard is preferable to the aftermarket ones.
