90
so the 2002 Forester is still sitting on OEM struts at 251K - not too shabby, LOL I have noticed that she has seemed a little "bouncier" lately, but a larger concern at the moment is the left front axle that needs to get changed out - before it falls apart. Have ignored the clicking from it for far too long.
whatever works for you. I dont like the mushy feel of the Gabriel struts. just discovered today that I need new struts on my Forester - leaking oil the fronts pretty badly, rears are little better, but not by much - it will be getting KYBs
Gabriels are pretty soft - if you like that, then they would be ok. Same for Monroes. the best strut available new for a Subaru is KYB
CD won't eject
heartless replied to RDB3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
perhaps it is time to look into something aftermarket instead of used OE units? I am running a Sony head unit in my 2002 Forester - it does play CDs, but also has a usb port that i can plug a thumb drive into and play music from that, or charge my phone, or whatever.. it also has bluetooth for hands free phone use (my primary reason for making the swap), and can also play music using the bt as well.. far more features than any stock unit of that era would have. there are wiring adapter kits available from Crutchfield.com so you don't need to cut any of the stock wires. wire up the adapter harness to the stereo unit, plug it in, mount, and enjoy -
you cant find them because they dont exist. springs are most likely fine, unless they are broken, rear top mounts should also be fine. KYB has top mounts (for front) and struts. If you dont want to deal with compressing the springs when you get the new parts, pull the assemblies off the car and take the whole works to an independent shop and ask them to do it. One near us did the assemblies for the other half's 06 Outback for about $30 oh yeah, almost forgot.. the brake lines run through a small bracket on the struts.. to avoid opening the lines, pull the clip that holds the line in place, wiggle it free, and cut the outside edge of the bracket off to slip the rubber line through - we used bolt cutters to do this - just enough to get the line out.. same can be done to the new strut to put the line back - the clip will hold the line in place just fine on the new one.
pretty much, yes. old, dry vacuum lines (23 yrs old) can easily crack, or just not seal well any more. Good practice is to get some new line in various sizes and replace everything you can get at. Not that expensive to do and frequently will solve those "head scratcher" issues. There are a few smaller sections that can be a bit of a pain to get at, but they are entirely do-able with a little patience and perseverance.
http://jdmfsm.info/Auto/Japan/Subaru/Legacy_Outback/1996/Service Manual/ENGINE SECTION/ENGINE/ second pdf from the bottom (ends in 5971) is a diagnostic table listing the most common to least common causes of various issues. Perhaps you should take a look at that. The symptoms you are describing could have multiple sources, including bad vacuum lines, a cracked (or poorly connected) air intake tube, etc
just an educated guess, but that car/engine (1997 model year), according to build date & model year, would be interference. 1995 model year is definitely non-interference. 1996 model year is supposed to be non-interference, but I do not have any personal experience with that year. I am sure others can verify. 1997 model year is interference from all info I have seen. generally speaking, a model year starts in the fall of the previous year - with some variation depending on manufacturer edit - just realized you are in Spain.. European markets are quite a bit different than the US market.
what he said ^^^^^ you paid for the warranty - now get your moneys worth. I honestly can not believe that anyone told you that amount of metal shavings on the magnet was "ok" - there is no way in hell I would have even put that tranny in a car. that is just nasty looking.
