90
this... A bad battery can kill an alternator by making it work more to try to recharge it... A bad alternator can kill a battery by a)undercharging, leaving the battery to make up the difference while the car is running and thereby discharging it, or b) overcharging and cooking away the acid, causing damage to the plates... Take the car to your local auto parts store... most will run a free charging system diagnostic for you if you ask. the system will be checked with the car off, and with it running at idle, and they will (should) ask you bring the rpms up to check it at "driving" speed.. also with all accessories off, and again with accessories on (lights, radio, heat, etc).
thanks guys, but that was experience talking there.. been there, done that a couple of times now, LOL first time it happened was on the old GL, bad parts store wires, one started arcing through the boot at the plug end.. was a good couple hours away from home when it started.. a few good wraps of electrical tape got me home. Ordered some NGK wires right away. 2nd time it was on the 95 Legacy - the coil pack had gone bad.. would only do it (stumble/misfire) when it was damp out, too...I could see the arcing, even in broad daylight, when i popped the hood.
you get a code for a misfire on cyl 3, but think it is a sensor or fuel related issue? really? misfires can, and do, foul and/or damage the spark plug.. change them. it is relatively cheap... same with wires... not that expensive - but do NOT use the cheap parts store brand wires... OEM or NGK ONLY. Then, and only then, do you look for other causes if the issue still persists.
another vote for KYB. might want to possibly get the front tophats at least.. rears don't usually have many problems. fronts - the bearings tend to go.. if you have them on hand and need them, you only have to do the job once... if you don't need them, return them. they are not typically called "inserts" - just strut, and spring - the two together are an assembly.
ok.. if you know how to clear the air from the system, but are still getting air pockets, this would lead one to suggest a head gasket failure that is allowing combustion air into the system. no thermostat/cooling system mod is going to fix that. if you are looking at doing this mod "just because" - well.. do what you want - it is your car after all - but i think the general consensus here is you would be wasting time, energy and money doing it.
Don't be sorry, and yeah, sometimes the guys tend to be a little blunt.. us long timers are used to it, but we sometimes forget new folks are not, lol in all seriousness, the mod you are considering is not something even remotely needed on a daily driver. The correct thermostat, installed properly, will do more for you than putting all kinds of time & effort into something that is completely unnecessary. a little tip when filling your cooling system... Fill the block first, thru the upper rad hose.. take your time, and make sure you get the block completely full before putting the hose on the radiator, and then filling the radiator. If you have the correct thermostat installed, it will seep coolant through the jiggle pin hole, into the lower rad hose, pushing air out thru the radiator. having the nose in the air does help, but filling the block thru that upper hose works beautifully nearly every single time. I have owned several Subarus over the last 18 yrs - from an 89 GL wagon with the EA82, a couple of early-mid 90s Legacies with the EJ22, and currently a 2002 Forester with the EJ251. I have never had a problem with trapped air using the rad hose method of filling the cooling system.
Agree with Texan... if it was not doing this before being parked for a while - first thing to check are the calipers - slide pins specifically. The caliper should move freely & smoothly on those pins. failing u-joint could also be a source of vibration. the other half just changed out the driveshaft on his 2006 due to a failing joint.. his was so bad he had a squeaking noise in reverse, but also had a vibration at certain speeds (would have to ask what speeds). both went away after the new shaft was installed.
what, specifically, is wrong with the tranny? the Subaru 4EAT is a fairly robust unit.. it may just need a fluid flush, or something else simple. if it is something more serious, on one this old, I would go with a lower miles JY unit myself.. just make sure the gear ratios match between tranny & rear diff. Oops - just noticed you state it is a FWD unit.. so disregard the gear ratio thing.
