Brick
About Brick
- Birthday 06/02/1968
Location
Shoreview
Vehicles
`01 Forester, '97 Legacy
Brick's Achievements
Member (2/11)
10
Nope, pretty consistantly tied to wheel rotation, although I've had bearings on other cars behave in the manner that you describe. It has to be either the diff or bearing--I hope it's only the bearings, the car only has 56k. This one might be a job for the dealer as I don't have a lot of time to mess w. it right now. Sounds like rear bearings are a general issue on this vintage vehicle though. Thanks!
Have an issue w. my 01 Forrester. I was getting what I thought was a lot of road noise from my tires (mc radials put on by the PO that were about shot), so I took the plunge and got some new rubber--minimal change. The sound from the rear, increases (sort of like growl of an off-road tire) w. wheel rotation speed. I'm now suspecting wheel bearing--altough this sounds like no other bearing I've ever heard. Is this a known issue w. the Forrester (56k on the clock)? Simple fix? Please advise, Thanks in advance Eric
avk: Good to know, and I checked it out. There seems to be no binding or flattening in the hose as it comes out of the rear gate, and the hose still has it's flexibility. I may however splice in some vaccuum tubing to keep this from being a problem. ferret: I'll check this one out, this type of thing was a pretty common issue on a car I owned some years ago (700 series Volvo). Most folks just kept a small supply of valves on the shelf at home and replaced them when they did a tune-up. How far downstream from the pump is the valve? Thanks guys! Eric
Stupid question follows: Recently and for no apparent reason, the rear window sprayer on my new-to-me 01 Forester has stopped working. Caveats: 1. The pump still works (it makes noise at least) 2. I can feel movement in the hose when the pump is run--I don't feel pressure per se though. 3. Fluid is above the intake level for the rear sprayer. The fluid ran a little low, and I'm suspecting that I just have a big-ol air bubble in the system? Is this common? Or is there some other piece of plumbing I need to check? Thanks in advance, Eric
