AndrewW01
Everything posted by AndrewW01
  1. still no luck I actually got my hands on a brand new cam sensor and decided to throw it in the car and see what happens and still no start or rpm read I'm lost at this point lmao this is my first subaru to work on and I have no idea what I'm missing I know for sure it has to be something with the ECU not getting some data because we have spark and fuel and compression etc it started on starting fluid like I said before and I did confirm I had fuel going to the motor
  2. I don’t have a oscilloscope and your saying if one of those sensors are not giving signal then there’s no power going to the injectors leading to the injectors not firing fuel into the motor?
  3. Alright update still no luck I decided to spray starting fluid into the intake and it started immediately and died so it sounds like a have a fuel issue so I took the fuel lines off the filter and I have fuel going into the filter and out and I replaced the crankshaft position sensor and still no luck im always not getting a RPM read on the gauge
  4. I bought it a few months ago and it’s been my daily since I bought it and not as I know of and all vacuum lines are connected I’m confused is there a crank position sensor on the H6 3.0 on my 2003
  5. Update on the car I can 100% confirm there are absolutely no current DTC or stored DTC in the computer now I need to check the crank position sensor like a few of y’all suggested but where is that sensor located I can’t find it online the only thing that pops up is the camshaft sensor it has the H6 3.0 motor 2003
  6. I have a 2003 Subaru Outback V6 3.0 I was driving down the highway around 60Mph and all of the sudden the car shut off and every light on the dashboard was on. I got the vehicle towed to my house and found no trouble codes and the car only cranks but no start I did replace the spark plugs a few weeks ago so I decided to put a new fuel pump in the car no fix. I decide to hell with it and put the car in neutral once I moved the gear shift I noticed a loud humming noise coming from under the car as you can hear in the audio clip I provided below. If anyone knows what my problem is or any help is much appreciated thank you ps I also have a full and brand new battery in the car and no voltage drop when cranking the car IMG_3087.m4a
