linkthehero1234 started following Frankenstein ECU Question , EA82 shift linkage with EJ transmission? , XT wiper conversion? and 6 others
Is it possible to use an EA82 shift linkage with an EJ transmission, or will I have to make a custom linkage? Specifically using an STi 6 speed.
Is it possible to convert an XT/6 from the single wiper system to the dual wipers from another EA82 car? I'm swapping an STi 6 speed into my XT6 and the wiper motor bracket is blocking where the clutch master cylinder should go. If it is possible, is it even worth it, or should I just cut a notch in the bracket and remove the motor when I need to add fluid?
Anyone know where to get XT6 parts? Going insane looking for them
Row52 doesn't list any XTs, and car-part.com has some, but none say the transmission crossmember is available, and I've emailed a seller for a digital dash to no response (but maybe it was just that particular seller)
Cybrid steering rack with regular pump and fluid?
Basically the title, can you use a Cybrid steering rack with a regular engine-driven pump and fluid? Or do I need to replace the rack?
that's my thread lol... honestly, the only thing I need to know is if the center crossmember mounts to the middle of the front and rear ones or if it's offset, then I can make a CAD file to get it custom made. If I make a CAD file I'll release it so others can make it too, since I know a few people in some facebook groups are looking for the same thing.
Specifically looking for manual transmission crossmembers... if anyone has a set for sale, knows where to find one, or even has one that they can measure, please let me know because I'm going insane looking for this...
Does anyone have experience with AGT Engineering?
I found a company in Australia called AGT Engineering that makes a CANbus emulator, which if I understand correctly, will allow me to use a stock Subaru ECU to drive an EZ30R essentially outside of the car (though immobilizer components are needed). Has anyone used this? How well does it work?
Transmission Crossmember question
Posted this in the new gen forum but this might be a better place. I'm putting an sti 6 speed into my XT6 and looking for a crossmember. My car started life as an automatic so I don't have the XT6 manual crossmember and finding one is gonna be impossible, and don't have a welder so would rather not go custom. Is there any EJ (or other) crossmember that will work? Here are the measurements (all from the centers of the bolts) Green line: 20 and 5/8 inches Red line: 2 and 3/8 inches Blue line: 13 and 1/2 inches
EJ Transmission Crossmember Question
Just found out that they aren't the same for all EJs, so here are the dimensions that I'm trying to match: Green line: 20 and 5/8 inches Red line: 2 and 3/8 inches Blue line: 13 and 1/2 inches (all measurements are between the centers of bolts) Does anyone know if there are any crossmembers that an EJ center (these are all the same, right???) can mount to that match these dimensions? Front and rear don't have to be from the same car.
Gas pedal question
Sorry for the late reply, I'm putting an STi 6 speed into the car (which was originally automatic) and converting to a hydraulic clutch, so I need to change the pedals so they can work with the hydraulic clutch and move the throttle cable (if necessary, I might be able to go without moving it) so it doesn't interfere with where the clutch master cylinder mounts to the pedal box
What are the dimensions of the rear transmission crossmember from an EJ (I think the automatic one would work too?) I'm specifically looking for the spacing of the mounting holes to see if it can fit in an xt6
Spec B Hybrid Axles in an XT6
Basically the title, will spec b rear axles work in an XT6? I assume they're the wrong length, so would the inner joints swap onto the XT6 axles for an R180 swap?
Gas pedal question
Is it possible to use the gas pedal from an XT6 with the brake/clutch assembly from a newer EJ car? Or, can an EJ gas pedal mount to the brake/clutch pedal assembly instead of the floor? Also, how hard is it to move the throttle cable down a few inches on the firewall on an XT6?
Would a 2004 ECU for an EZ30D car be able to run an EZ30R? I know that the R version has AVLS, but if I understand correctly, the engine will work without AVLS being wired up. I want to get it to run on a stock Subaru ECU (preferably without immobilizer, hence 2004) to get a smog check, then switch to standalone. I assume the pinouts would be different between the ECUs but I'm willing to modify the wiring for that. Is there anything else that would prevent me from doing this? (after writing this I realized that DBW could be a problem, but could the DBC metal manifold from an EZ30D fit on an R?)
Another XT6 Crossmember Question
@Crazyeightscan you measure your crossmember setup? I need to know if the front piece is symmetrical (and if so how far from the mounting holes for the center piece to the mounting holes for the front piece itself) and where the center piece mounts on the back piece.
linkthehero1234
