krypton
Everything posted by krypton
  1. I don't have a manual unfortunately. So you think then that the diff lock fuse will disable rear wheel drive ? I did try putting a fuse in there and went for a drive around the block, the steering was heavier and there was less power similar to what it would be like if it was only 2wd, it also felt a bit strange going around corners. I just can't understand though why they would call that fuse Diff Lock and not 4WD as they do other GT's ?
  2. What is the purpose of the Diff Lock fuse under the hood in my 95 Gt B spec ? I have heard from some people that putting a fuse in here will make the car FWD only, from others I have heard that it will only split the power 50/50 between front and rear wheels. Which is correct ?
  3. I have a 95 Legacy Gt-B Spec and under the hood is a little box labelled 'Diff Lock', it looks like it holds a fuse but is currently empty. Can anyone tell me what this is for ? Is this the same as the 4WD fuse that I have heard can usually be found under the hood that can be used to convert the car to 2WD as I can't find this ? Thanks.
