SaltyMike last won the day on September 7 2021
SaltyMike had the most liked content!
Location
Middletown CT
Referral
Google
Biography
First time vintage Subaru owner, bought a BRAT in July of 2021. Have always wanted one and finally got to do so after graduating college. Am looking to meet more owners of Brats/vintage Subarus.
Vehicles
1982 Subaru BRAT DL
Recent Profile Visitors
SaltyMike's Achievements
Advanced Member (3/11)
7
Hey everyone, I just recently began doing a dash swap on my '82 Brat. Besides my original dash being worn beyond repair by the sun, I've been meaning to do this as it will be the next major step in my EJ22 swap project. I was able to get a very clean uncracked tan dash for a great price as well as a complete '82 GL wiring harness, which will make the wiring job as easy as it possibly can get. However, I just have some questions while I am doing this: It's tough to tell for sure, but are the air ducts behind the dash the same in both DL as well as the GL? It seems as though the center area by the climate control may be slightly different, but it is difficult to know for sure. Also, while removing all of the wiring to swap the GL harness over, I noticed that there are quite a few wiring connections that are seemingly unused and do not go to anything, in particular where the harness in the engine bay connects to the harness that weaves behind the dash. If they are completely useless, is there any harm in removing them to sort the wiring a little more?
Hey everyone, Recently I've been having issues of what appears to be an excess amount of pressure building up within the fuel tank. I know that there is always supposed to be some pressure that releases whenever you remove the gas cap, however this seems to be an excess amount to me. It's to a point where it may take two hands to take off the fuel cap and will result in major fuel spray if not removed super slowly. Coincientally, I just started noticing this after having done my EJ22 swap, but nonetheless I suspected there was a blockage in one of the fuel/vent lines. None of the lines are crossed, and I was able to hearing bubbling in the fuel tank when blowing air into the return line, so it must not be the return line that's blocked. Through doing some fuel system research, I learned that there is a ventilation box for the fuel system that is located in the passenger side fender, so I checked that out to see if anything was gummed up in it. I found that the box has three lines connecting to it. Two of the three lines are have roughly the same small diameter. However, the other line is a lot larger in diameter (at least at the point where it connects to the vent box, it seems to taper down to a small diameter similar to the other two as the line continues). I blew compressed air into all three connecting points on the vent box itself and nothing indicated that there was a blockage on the inside (I'm unable to take apart the box itself to inspect it.) Next step was to blow air into the three lines that connect to the box. When traced, one of the two small diameter lines connects to the passenger side of the fuel tank. The larger line also connects to the passenger side of the fuel tank. The other small line is the vent line that pops out through the fire wall, and by blowing compressed air into it I confirmed that it was not blocked. The small line that connects to the fuel tank blows air out of the fuel fill port itself when the compressed air is introduced. However, nothing is heard when blowing compressed air into the largest line. Would anybody have an idea on what the largest line connectiing to the ventilation box does? Is what I am describing indicative of a blockage somewhere?
Just last night I swapped the evap and return lines coming through the firewall, as well as back at the tank. Unfortunately, it doesn't seem to have made a difference. Upon inspection though, it seems as though the evap and return lines are approximately the same diameter. I measured both of these lines at roughly 4mm. Seems strange to me, because when I read a write up about converting the fuel system for an EJ22 swap from Phizinza, it says that the return line is 3.2mm and the vent line is 6.3mm. My Brat is an '82 DL. From my understanding, this was a bit of a strange year for the Brat (only 2nd gen body with a hardtop option, single range 4 speed, Carter-Weber carburetor instead of a Hitachi carburetor). Maybe this uniqueness has something to do with why these lines are the same diameter? Not sure, I may be missing something here. If not, it sounds like I'll have to run a new line to resolve this.
On the front of the tank, there are two lines directly next to one another. I know that the larger of the two is the feed, and I assumed that the one directly next to it was the return. (This post shows what I am talking about: There's another line that wraps around the tank (evap I'm assuming) which leads to a canister located in the right rear fender. There's two other lines that come out of the tank right above where the fuel fill port is. These two lines also lead into that canister located in the right rear fender. I tried to switch how I hooked up the return and evap firewall lines, guessing that maybe I had swithced them accidentally and that this was causing the high fuel pressure. This just lead to increased pressure in the fuel tank and purging of fuel through the return line. Is there a write up on the forums here on how people have swapped the lines so the return line will have a larger diameter or do I need to run an entirely new return line?
Update: Got a fuel pressure gauge on the Brat recently, and discovered the source of the rough idle: high fuel pressure. I believe that the 2.2 is supposed to run around 30ish psi. My fuel pressure gauge gave me a rating of 65 psi 😬 Now I'm trying to figure out why I'm getting such a high fuel pressure rating. I disconnected what I am 99% sure is the fuel return line coming from the firewall (next to throttle cable coming through firewall) and I got a way more normal fuel pressure of around 30ish psi. I blew into a piece of fuel hose connected to the return line to see if there was any resistance that would indicate a clog. I could easily hear bubbling in the tank when I did so. Just in case the power of my lungs wasn't enough, I blew some compressed air through the line with the same result. I hooked the line back up and got the same pressure reading of 65 psi. I am using the stock return line that came with the Brat. May be common sense, but could the change in diameter between the fuel return port on the EJ and the fuel return line on the Brat cause such a drastic increase in fuel pressure? Out of all of the write ups I researched while doing my swap I don't remember seeing anything saying that I need to run a completely new return line of larger diameter, just that I would need to upgrade all of the rubber fuel lines to be EFI grade.
Apologies for the late reply! Got busy with work and couldn't check the forums. Anyways, the scanner wasn't throwing any codes specifically related to a bad idle. However, there were multiple EVAP codes thrown as well as two other codes: P0172 (Bank 1 Too Rich) & P0301 (Cylinder 1 Misfire). Besides the surging idle, the engine feels as though it is running pretty well. The surging idle makes itself known once it has had a few minutes to warm up. While driving, it runs pretty smooth but there's probably a 20%-25% chance that when I coast to a stop in neutral, the car will die on me. That being said, I'm assuming that the cylinder misfire is a result of the rich environment it's in (fouled plug maybe, but I haven't gotten the chance to check it). From a cold start, the EJ22 does take a few seconds to start, and it actually sounds like it's struggling a bit. Once it's warmed up and then shut off, it doesn't have a problem starting up again. That may be a contributing factor, I will look into this, thank you!
Hey everyone, I have an EJ22 from a '98 Legacy now in an '82 Brat. I've found that once at operating temperature, the idle begins surging. It is running rich at idle and at 2k rpm. After hooking it up to a diagnostic scanner, it was discovered that the ECM is fluctuating between a closed loop and an open loop when the idle surges. When in a closed loop, the engine wants to stall. I hope I put this post in the right place rather than the Retrofitting forum. I figured that since this question pertains more to the operation of the engine rather than how to put this engine in an older Subaru, then its best place is here. Thank you!
Hey everyone, I recently had an issue where the brake pedal in its resting state was not pushing in the switch that controls the brake lights. I got this issue fixed, but my dumb self first tried adjusting it from the bracket that sits on the threaded part of the booster push rod. I learned that by doing this, I unintentionally moved my brakes out of adjustment. Now I’m worried about my brakes dragging but its not quite roadworthy yet to find that out (finishing up engine swap). Is there certain adjustment specs for the brake booster push rod? Thank you!
Will EJ starter motor work for a 5 Speed D/R?
SaltyMike replied to SaltyMike's topic in Old Gen.: 80's GL/DL/XT/Loyales...
When you say you went to the EA82, you're referring to the flywheel, correct? -
Thank you Bennie, I completely understand that it’s not necessary to remove the Brat’s wiring harness when doing this swap considering it’s mostly going to be powered by the EJ harness, but I just figured I’d clean up the engine bay a little bit and get rid of the rat’s nest of wires I pulled from it. Just want to be safe before cutting anything though. Just to confirm, that picture with the three relays and cylindrical connection point mounted on the metal bracket is all for the A/C? That’s the bulk of the wiring in the engine bay currently, and it just seems odd that there is so much wiring for just the A/C. Plus some of those relays have wires going to some important stuff, such as the headlights and the brake master cylinder. Through a quick parts lookup, I’m pretty sure the cylindrical connection all the way to the left with the hose exiting out the back is the refrigerant pressure switch, so I can rest assured that it’s for the A/C system.
