yuba49r
About yuba49r
- Birthday 11/30/1973
Location
GrassValley,Nevada County
Interests
River, exploring,
Occupation
Disabled
Vehicles
86 GL Wagon 4x, 01 Forest
yuba49r's Achievements
Newbie (1/11)
10
Can a 4 prong Carb Work on a 3 prong set-up
yuba49r replied to Petersubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hey there, I recently had to replace my Carb. on an 86 GL. If I remember right, the only difference was the ground wire. Someone can correct me, if I'm wrong. I think it used the metal body in the 3 wire version, the 4th wire was a ground wire.? I think....I can look after I get mine back from the shop, had a lifter problem, and need to check the valves. Also, geting a code 73 & 52 from the trouble light. Getting it looked at by a shop that only deals in Subies. Good luck! Peace, Yuba49r -
Thanks for all the replies, I'm not getting any backfiring issues, no missing at all that I can tell, it does idle a little rough at first start. It smooths out after the warm up. I plan on getting it all checked out, asap. Right now, my 86 GL wagon is getting fixed, I miss it. Peace, for now. I'll keep you posted.
Hey there folks, I bought a 01 Forester for my wife, it ran fine, with no CEL when I test drove it about 50 miles before I bought it. It had 131k miles on it, it's an L 5spd. A no frills grocery getter. Now, it keeps giving me this code, the car is idling normally at start up, around 68 degrees from the data I pulled from OBD 2. I called my mechanic, and he said to check for corrosion around the plug wires, there isn't any. So, he thinks it may be a tight valve, something that should have been done at 105k. So, this is the next project, right after he finishes my 86 GL Wagon. I'm jonesing to have it back, I love that car, with the dual range 4wd. I live in the hills, and it gets me out where I want to get, winter or summer, when other people can't leave home, lol. Anyone have any other things it could be for me to bounce off my mechanic, let me know. Peace
Ignition Pulse System malfunction
yuba49r replied to yuba49r's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ok, update needed...I've done plenty of work to the Wagon recently and am still in the process. I replaced both CV axles, front wheel bearings. Then, it wouldn't pass smog? Later the same day, the timing belt almost kept me from home. I took it apart when I got home to find a couple teeth had come off. So, I ordered the Ebay Timing belt kit with the gasket set too. Got a new water pump, resealed the oil pump, replaced the cam tower seals, crank seal. Replaced the roller, belt tensioners, and both belts, even though the drivers' side was the broken one, I like to get ahead of potential headaches, so, basically I replaced everything I could in front of the engine. In the process of re-tightening the tensioners, the threads stripped, so I got a heli-coil kit and went from there. The job went fine, I thought, but the tensioners kept coming loose, until I really tightened them hard without the torq wrench, lol. I also broke off the bolt on the high pressure side of the oil pump in the block, got a extractor and it came out, shew!, went to the junk yard got a new timing belt cover set, and the oil pump bolts. Fixed! But, eventually I left the covers off, until I get it all the way fixed. I didn't think I had the patience to remove the valve covers and replace those seals, so I left them be. I also replaced the exhaust gaskets and the donut gasket from the exhaust coupling behind the Cat. and replaced the Oxy Sensor after re-tapping the threads, someone had put JB weld in it, that's how bad it was! I finally I got it to run, then the thing started to have new symptoms, lol. I applied for assistance through the CAP program here in California, which you'll see was a mistake I'm paying for now. They pay for $500 of the smog related repairs. I took it to a place that sounded like they did Japanese Auto Repair, I had to pick from their smog or CAP approved repair facilities. Well, they said it first needed a new carburetor, so I got a reman one for a little over $200. They made me pay extra to install it, they also said the PCV valve was bad, and a hose. I get the car back with the newly issued smog certificate, and it won't accelerate over 3100 RPM!!! Then, the choke circuit seems to be malfunctioning, and it developed a lifter tick, which never happened before. WTF??? They charged the State of California like $490 for this little bit of work, they called most of the time involved; diagnosing the problem...Well, I didn't really know who to call to complain or make them fix the problem. Anyway, I've since taken the distributor apart, lubricated the little weights, tested the vacuum advance units, I have a Hitachi Carb with the Nippondenso Disty. All seemed fine, checked the barrels in the carb primary & secondary seemed to be squirting fuel, so what gives? When the lifter tick, or whatever it was started I parked it. Now, I've taken it to Steve Barsotti in Newcastle, all he does EVER are Subaru's, day in, day out. So, far today he said, he has found there PCV job was totally connected wrong, also was totally missing a certain hose needed. Also, there is a code 52? He said he would figure it out, also he wanted to replace the Oxygen Sensor I put in, either I damaged it, got thread crap on it or it's a cheap piece of junk, you pick, lol. He said he thinks it needs a fuel filter, so in a few days I should know, he aid the lifter thing happens when an older Subby has been sitting a while. So, driving it, and some high test, plus Sea Foam wouldn't hurt things. I did notice when I had to drive it down there, approx 40 miles drive, the noise wasn't noticeable like before, it still had the acceleration issues, but no ticking. So, hopefully they won't have to get into the engine, and cost me an arm and a leg for my old trusty! I have brand new tires and brakes too, I do need to rebuild/replace the front caliper piston seals. The passenger one is sticking at times, it's not the Ebrake or the hill holder they are functioning fine. Well, This pretty much updates things. Peace, for now -
Ignition Pulse System code, what does this mean? I got out the code, now what do I do with it, since the Haynes book I bought is crap. I have a 86 GL Wagon, Mfg. date 06/86. VIN # JF2AN53B9Ge471708. I can't seem to find any wiring diagram to match the one I have, or vacuum either, I am really frustrated with this thing, regret buying it. I can't figure out whether the rear wheel bearings are a one piece system or two, the books aren't helping. I think I have cruise control, but I can't seem to make it work, the AC doesn't want to work either. Are there any books worth the paper they are printed on? For all I know I have the wrong code, and I can't find the memory connector, supposed to be black?
