About SakoTGrimes
- Birthday 08/25/1984
Location
Grants Pass
Interests
Blowing up EA82s, getting 58.36mpg, driving slow, wheelin, breakin stuff, acting a fool
Occupation
Organic produce guy
Biography
I'm obsessed with fuel economy and masterful engineering
Vehicles
zero
SakoTGrimes's Achievements
Certified Subaru Nut (8/11)
10
tighten your lugnuts...
SakoTGrimes replied to monstaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My thread entitled "The Grand West Hollywood Misadventure" or something was caused entirely by loose lugnuts. I can't stress enough how important having them torqued down is. The minute of work is worth not having to run around LA at midnight and losing tons of money. -
Crank pulley falls off
SakoTGrimes replied to SakoTGrimes's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Tightened it again today, this time in 1st gear and the wheels blocked. Strange whirring still there and coming from the crank pulley, but I will try using Locktite. I was worried some permanent fastener had been destroyed, like what can happen to loose wheel hubs. -
My engine makes a whining noise, sorta like an electric drill, goes up with the RPM. I thought it might be an idler pulley going bad. And it stalls..... so, to allow myself to look at the belts and such while moving, I turned up the idle.... accidentally dislodged the throttle cable.... the point is: when I reattached it, I revved her up to about 5K to make sure the gas pedal would work properly, but then all the warning lights came on, and the mysterious whirring stopped. Because the crank pulley had come off. On the surface that contacts the engine there is an indentation that looks like a nub on the crank should fit into, yet the crank has no such thing (and it does not look like one used to be there either) so I figured it just wasn't bolted on tightly enough and put it back on, although I couldn't get it as tight as I want because trying to do so just cranks the engine. Once everything was back in place I fired her up and held her at 5K for about 5 seconds and sure enough the same thing happened again. So...... what the heck am I doing wrong?
Really!? It sure doesn't look very aerodynamic, but neither does the Mercedes C Class (cd in the low .20s) That would be super cool if my wagon really is that good. One day when I have it running properly I'd like to do the string tassel test to identify weak points and modify them.
No, I have not cleaned out the idle circuit. And I'm somewhat ashamed to admit it's because I don't know what that is. Is it a tube in the carb or something electrical?? So far all I have done is used some carb cleaner while the engine was running (back when it would idle) haven't turned any screws or anything.
Annnnnnnnnnnd, bump! Still not sure if I have found the ADV or not. More info: when car is super warmed up, coasting off the freeway, she will idle fine for a while and not sputter. Would that make it something other than the anti diesel valve? Would it be bad to turn up my idle screw a little?
In my opinion, airflow around the vehicle is the single most important factor in increasing fuel economy. Think about how hard it would be to stand up in a 65mph wind, now multiply your body mass by 5 and that's about the frontal area of your car. A lot of power goes to not just moving the car, but thousands of cubic feet of air per second. Even a high powered V8 car can get good mileage with tall gearing and a slippery shape (Corvette) Look at all the highest mpg cars ever built, they almost all have lower than average .cda's
LMAO! Be honest, did you go out and do that just to prove me wrong? Holy crap that was funny!
About Buying JDM Engines
SakoTGrimes replied to Quidam's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ummmmm, no.... the only thing we got that you didn't was EA81 hatches. America pretty much receives the piss of the mix on everything else automotive. -
I see I'm not the only ecomodder forum user here Yes, XTs pwn wagons in the cda department, but epically fail when it comes to hauling Christmas trees. One day I'll get one though to mess with. Mirrors are an easy fix. Get rid of 'em. For now my passenger is just folded in, but I'll remove it soon. Other plans for me in the future are rear wheel skirts and all wheel pizza pans, coroplast underbody cover, grille block, fuel injection conversion, possibly a 3.70 swap and port + polish (GF's dad is a CNC machinist woot) LLR tires, couple inches lower. Honestly an EJ22/18 (or EJ15!!) swap would probably be easier and more efficient, but I'm an EA lover. I'll mess with a Legacy or Impretzel when I have more money. As I've only gone through a couple tanks so far, I'm still experimenting with how RPM vs. speed effects my mileage. 55 should be better than 65, but then I need more throttle.... stupid carb! I drive 300 miles a week to work, so it shouldn't take me long to figure that one out.
Somehow, for some reason, there doesn't seem to be a thread devoted to aerodynamics.... That I could find anyway.... So, let this be it. Since I have become obsessed with fuel economy (57.51mpg in the Tercel baby!) I would like to experiment with modifying the EA82 wagon, which appears to be only slightly slippery than a Volvo brick wagon. Currently I am at 29.5mpg in the wagon..... not bad by most people's standards, but I'd like 40 a lot better. I know it can be done. I will post any results here when I get the numbers. For now, does any body know the Coefficient of Drag of an EA82 wagon? Can't find it on the net, since nobody seems interested in it : (
Is this thing my ADV?? It's the only thing that even remotely sounds like what the book describes, and is the only thing on the carb with a wire, but it points out of the passenger side of the carb.
christmas pictures
SakoTGrimes replied to WheaT_BeeR_MaN's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Dude, I made a thread about this car years ago! Never had my camera when I saw it though! Was that by the Pit Stop Tavern? -
Hey, thanks for the info. I am out of the country for a few more days, but I'll be able to tackle the problem when I get back. Since this car is not my daily transportation I can take as much free time as I want to figure out how to fix everything the right way (rump roast opposed to my old way of fixing it just enough to get me to work and calling it good, ha)
