J41YD3D.
Everything posted by J41YD3D.
I said to hell with the GL-10 so I robbed the rear suspension components all the way to the cross member because that was bent after my snow collision; reminder to self don’t shy away from things tackle ‘em head on. I managed to get it done in a night just in time for the snow. The GL-10 is running ever worst so I think the next project is maybe combining the engines to get the turbo as well. Cheers everyone!
I got the mass air flow sensor where it has a needle the glides across bumps depending on what setting is needed, I think it’s that flapper. I’ve got a question unrelated to the health of the car but I’ve got a 92 loyale that needs a trailing arm. I’ve noticed the gl10 has disc breaks in the back the loyale has drums im wondering if I can just swap the gl10s assembly over and I wonder if the loyales master brake booster cylinder would be able to support it? It looks like it would be plug and play if so. And I’d gain disc brakes and a sway bar. I’ll give the gl10 a compression test, I tested the fuel pressure it’s getting adequate fuel the fuel pressure is good I got around 40 pissies. I’m just confused maybe the compression test will tell me what I need. Cheers!
I’m at a loss, this 130000 miles GL10 was running fine when I purchased it and 2 weeks into my ownership it died due to what I believe is fueling issues. It’s been sitting for some time now but I’ve been throwing parts at it. I replaced the mass air flow sensor used a 300zx terminal because the stock one was shot so reworked all of that to find my issue persists. It ran better but it was still a far cry to what it was, so I read the codes and learned the coolant sensor in the intake plenum was no bueno and I replaced that now it holds an idle and even adjusts itself to sustain an idle not like before. it was looking up until I wanted to hear the flat four no exhaust rev and soon as you give it throttle it sputters and dies. That is new because before I would give it the beans when it would struggle to idle and it would give in to my demands so I’m lost as to why it’s a piece of spoob, I’m wondering if my wiring job to the maf sensor is boo boo, and where I went wrong. It no longer reeks of gas but it smokes more than my grandmother. My pops tells me he think it’s missing and there might be a dead cylinder, I think he’s full of spoob but it does pop here and there but for it to have a dead cylinder I just don’t know it’s not far fetched he’s not a Subaru dood but he’s been around enough cars to know I’m not saying I know everything but I also have a set of ears and eyes. I digress im just looking for some advice and where to go from here, there’s a lot of (with all do respect) old heads and Subaru doods that have been doing this for sometime, I haven’t give much but I’m looking to the stars on this one. Cheers
I have a 92 subaru Loyale and a 86 subaru gl10. The 92 loyale has been my daily driver for nearly a year but it’s been stuck in 4WD and I’m tired of the chirping slipping and I want to just floor it and go. I just recently bought a low mile 130000 mile gl10 which was supposed to replace my Loyale but it has fueling issues it’s a piece of spoob all around it wasnt taken care of but everything works besides it doesn’t run well so the wagon will continue to be the main so I’ll use it for parts. The gl10 has the push button 4WD auto I’m wondering if I can just throw in the automatic transmission i don’t know what all need to happen in order for it to be compatible. In my head I bolt up the new transmission and connect a few wires and life is good right? Help me… merry Christmas happy Hanukkah cheers ahead of time
92 Subaru Loyale 4WD cladding disaster
J41YD3D. posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hello everyone, I have something simple I need help with. I rubbed a fence on the passenger side ripping off the passenger rear quarter cladding and I’m not sure how to put in back on. The clips are still intact but the trim has come off completely. What do I do, someone help me! My car went from vintage to shot box in a matter of seconds. Thank you everyone, enjoy the rest of your day! -
1992 Subaru Loyale wagon 4WD won’t start
J41YD3D. replied to J41YD3D.'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
It definitely was and to make matters worst I had the 2nd cylinder and the 4th spark plug wires mixed up. She runs no problem now. I guess that’s why many people didn’t respond because they realized I was an idiot soon to figure it out lol. -
Recently I pulled and resealed the whole ea82 engine in my 92 loyale wagon. I have since put the engine back in and buttoned up the engine, but I haven’t had any luck starting it. I realized my mistake first off, the timing was way of. I set the passenger side and driver side camshafts to 12 o’ clock. After watching miles fox on YouTube I’m pretty sure I have that issue fixed. However, I set the timing to the middle mark of the three marks on the flywheel. I started the timing with the drivers side setting it to 12 o’ clock then putting the belt on and rotating it 180 degrees so now it’s at 6 o’ clock. Then I moved to the passenger side set it to 12 o’ clock, put the timing belt on and proceeded to rotate it 180 degrees. After that I set the distributor to the first cylinder, while on the center mark on the fly wheel. I then rotated the engine until I got to the 0 mark on the flywheel but the cams where no longer at the top and bottom but I didn’t think much of. I thought I was solid so I put the motor back together and tried turning it over to no avail, played with the distributor for a while to no avail. I know I’m getting spark and fuel. Cranking it doesn’t give an uneven sound like it’s only running on a few cylinders. It’s even all the way through. I smell gas after cranking it and I backfiring through the intake. This is the first time I’ve ever rebuilt an engine so I need so help I’m lost. Cheers!
I’m in the process of rebuilding my EA82, I tore it apart after having a blown head gasket and decided to replace all gaskets and everything that looked like it’d give me trouble later down the road. I just started rebuilding the left side of the engine standing in front of it. I put the head gaskets on after having the block cleaned and these resurfaced, and cleaned all the head bolts to reuse them. Started putting the bolts back in to discover I have somehow only 4 short bolts, but there are 6 spots for the short bolts. It took me a second to figure this out as I thought the treads were bad, tapping them over and over again only to realize I’m not getting stuck but bottoming out in the hole. The long bolts don’t sit flush in the more shallow hole. I don’t understand how I have too many long bolts but I was wondering if there’s anywhere I can buy just the short bolts? If I need to I’ll buy a whole set but I know for a fact I only used the short bolts on the other side in the 3 middle holes. I’ve searched everywhere for head bolts for the EA82 but to no avail. If anyone could help I would really appreciate it. Thank you for your time, have a great night!
92' Loyale Wagon Engine Rebuild
I have another question, I was worried that I might mess something up removing the heads out of time. So I should be fine just removing the heads, and If so, can I turn the cam pulley back to where it is in time? Does I need to spin so many times before it's back in time? What's the process? I appreciate the help, thank you for your time. -
I didn't mention this before but the engine only has 156xxx on it, but your saying to just focus on the head gaskets? How long do the rings and bearings typically last? I'm guessing it's quite the process to split the block, should I worry about anything else while the motor is out? Thank you for your time. -
I'm currently rebuilding my ea82 out of my loyale. This will be the first engine I've ever rebuilt. It was supposed to be just a head gasket job but I thought if I pull the engine I might as well do it all while it's out. The task at the moment is tearing down the front of the engine. I set it to tdc with the three marks and I took the crank pulley off. Everything is still in time but when I was pulling the cam pulley on the driver's side I managed to knock it off time and I cannot put it back in time because the compression from the cylinder stops me from doing so. I don't really know what to do now, I had the idea of just continuing to spin it until the marks line up again but I'm not sure how many times I'd need to do that. I really have no clue where to continue from, can I get some help??
92' Loyale Wagon Stuck in 4WD
I was not aware that these vehicle were front wheel drive if not in 4WD. I'll make sure to check that out. -
Hi, I picked this rig up a few months ago and just figured out its "stuck" in 4wd. I pushed the button to disengage the 4wd only to be left with a motionless vehicle. If it's not in 4wd it doesn't move. I was hoping that it wasn't as serious as needing a whole new transmission but I've tired everything I could find on these old forums. I've tired going to the mechanism that activates the 4wd and that's actually about it. If theres anything, please help me! Thank you for your time!
