Pooparu
    4
Everything posted by Pooparu
  1. ya, a little. I had to use a hammer to pound down the metal around the hole to get the speaker to sit a little lower.
  2. You can see some photos with the link at the bottom of the page in my tag. I think they were 6" speakers, but I had to do a little grinding to get them to fit.
  3. Man I did the same thing at WCSS9 with my SPFI motor. Thanks to a little help for some good Subaru friends we got it out of the huge mud puddle and back to camp where I used some gorilla tape to block off the holes and then I turned my airbox on it's side and continued to mud.
  4. Hell ya that would be cool. You or at least I still need to buy axles, clutch, flywheel and a drive line after getting the rear end & the transmission. I could make up some of the money by selling my EA82 5sp Transmission with Jerry's kit and a drive line to someone interested in doing that swap into their Brat or Hatch. I'm going to keep the EJ swap stuff for my 78 BRAT.
  5. I'd hate to go through the cost and trouble of installing an RX transmission and not get the results I'm looking for. So at this point I should start looking in the direction of swapping an EJ transmission in. I know it's going to be a lot more work and money, but in the end it will be worth it.
  6. I was also talking with Matt and he was saying that the RX transmission wouldn't hook up as good as the EJ transmission. (traction wise) I just want my hatch to go when I take off, not just spin out.
  7. I have Weather Force Tires on my Hatch and Blizzaks on my Outback. If I were you I'd get the Blizzaks. They are worth the extra money. Not to say that the Weather Forces are crap, but I've been very impressed with the Blizzaks in the snow. Also if you can find Forester suspension I'd used that. It will give you and extra inch or so over the Outback stuff.
  8. so swapping out the stubs on the front diffs would not work?
  9. your intake system looks like a propane intake system.
  10. I've got Jerry's kit so I don't think the shifters will be a problem. Aren't the EA82 axles longer then the EA81 axles? Do you think I could swap the stubs from my 5sp 4WD front diff over to the RX front diff or will the extra length on the axles matter?
  11. I thought that the turbo hubs were the same as n/a hubs, but the difference being the spline count on the transmission stubs.
  12. How easy is it to find an RX transmission?
  13. I have a 1982 Subaru Hatchback with an EJ22 swap. What I'd like to do is to convert the drivetrain to AWD. Right now I have and EA82 D/R 5 speed 4WD in it. So What I'd like to do is make a list of everything I need to get for the swap so I can start to stock pile all the parts to do the swap this spring. That's where you guys come in. thanks, earl
  14. Well it's time to do some more work to the hatch. I'm going to add some power steering. I just got the rack and cross member from the junkyard the other day. Now I need to tear it down and rebuild it and paint it. I'll post some photos along the way. I'm also going to install some small 1" blocks between the frame and the cross member to help with the camber issue.
  15. - 14" Peugeot Wheels - Fender JDM Mirrors - Volkswagen VR6 stereo Antenna - H4 Headlights - Turbo Rear Disk Breaks - 1992 Legacy EJ22 Motor with Cone Filter - Diamond Coil Pack - A-Style Push Bar with Lots of lights - 2.5" Straight Back Exhaust with a Borla Muffler - 1993 Legacy Seats - 1987 GL 5 Speed Dual Range 4WD Transmission - Custom Drive Line - Pioneer Premier Stereo and Speakers - 1980 Toyota Celica 5sp Shift Knob - Shaved all Emblems and Trim off and filled in - Dark Window Tint - RX LSD Rear End - Custom Painted Satin Black - Hood Pins - Hella Horns - Optima Battery Relocated to Rear of Hatch - Yakima Rack - Passing Light (in the grill) - Original to the car Subaru Rubber Floor Mats - I also put on a fresh set of Bumpers - More to come...
  16. Thanks, I feel super old.
  17. We just started a Myspace page for the biz. Check it out and join up as a friend. http://www.myspace.com/bandrsignanddesign
  18. I got one of these new kits at the show and it is soooo cool. My kit is off getting powder coated, as soon as I get it back and have the time I'm puttin' it on my BRAT.
  19. Pooparu
    lsd?
    Ya, I hear that a clutch type LSD with 4.11's will be up on ebay this week. Check it out.
  20. Last weekend I saw a couple of Gen 2's at the Foster U pull it.
