jimpon
Location
deadwood
jimpon's Achievements
Member (2/11)
10
well gary I think you are a lonely old man that likes to *************** about little things. sometimes when you are a frustrated subie owner all you can say is HELP. Your negative remarks to some posts, (ie about saying things the way people should post or how to title a post) really makes for unenjoyable reading. if your that grumpy about this stuff stop reading the posts or learn some patience. I am speaking for myself of course. sorry to all other readers for jumping this post. Jim
headjobs are so fun????????????
jimpon replied to jimpon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
so do you see possible problems with this? if so what are they? Jim -
well just finished putting new heads on my 88 gl10t. even after reading all the posts on this subjectI neglected to blow out all the galleries on the cam towers. I learned a lesson though . just because I was very careful in putting on the sealant between the cam tower and head didn't mean that it was a cinch,not by any means. after pulling r head I found no (visible) reason my lifters wouldn't pump up. so I started to blow air everywhere in the oil system, and behold a blob of three different colors of sealants came flying out of the main journal for the cam tower. this must have been in the system since before I got the car. I really didn't like the thought of having this possibly happening again so I found a way around the goop. I went to the oring building kit and got a long oversized piece, some superglue gel and some clamps. I placed a small dot of glue and began stretching around the groove placing dots of glue ocassionaly. the I placed my support oring with a couple more dots of glue. put her back in the car , not a problem yet.
I have a bunch of ea82spfi parts, and actually a whole car 91 loyale.come up to deadwood and I'll hook ya up. Jim
if ya can't find one I probably can help
EA82 Automatic tranny questions
jimpon replied to torxxx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
had that nasty clunk and it turned out to be a broken shock. couldn't see any damage, even after removing it. replaced it and no more noise. -
Codes 22, 33, 35 & 51....
jimpon replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
with my 88gl10t I have had to go around and repair the ground wires. I use a shakeproof lock washer in between every wire and the body with some anti corrosion grease. works quite well. Jim -
Insanely high voltage readings...
jimpon replied to Danbob99's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ok so you guys are losing voltage regulators, why are they going? I have been driving and working on subs since the mid seventies and I have never had an alternator problem.(must be why I have 2-3 laying around) anyway what is causing this? Jim -
has anyone done this? I have access to a motor and tranny from a xt6. Jim
Need Clutch disc by weekend for EA82 4x4
jimpon replied to Scott in Bellingham's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have a used ea82t clutch. it's used but should have 50k left. you pay shipping and you owe me jim -
Crazy Idea altering cam timing, might work
jimpon replied to Rollie715's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what about the wasted fuel washing the non firing cylinder? Jim -
just bought GL-10, and I' m kinda worried
jimpon replied to Steven Romero's topic in Old Gen.: 80's GL/DL/XT/Loyales...
on my gl10t i had a leak on the cooling system that turned out to be turbo cooling system. is this leak on the pass or drivers side? Jim -
Alternator and ECU Code 35
jimpon replied to WhitAlpin's topic in Old Gen.: 80's GL/DL/XT/Loyales...
according to the fsm DO NOT DO IT. YOU RUN THE RISK OF FRYING SEVERAL DIFFERERENT SYSTEMS. Jim -
Diagnostic confirmation help (coolant on an 87 ea82)
jimpon replied to hush777's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had the same problem on my 88 gl found out that the head on one side was cracked into the water jacket. she would heat up right quick. I had no signs of coolant burn on the plugs, valves looked quite different. Jim -
thanks I'll try your suggestions. you any relation to glenn gross?
