14
Everything posted by forester2002s
My first thought is the rear drive-shaft (prop-shaft) bearings. But these usually cause vibrations when transmitting torque, for instance when accelerating in AWD. Same goes for the wheel bearings and half-shaft bearings. So it is unlikely that you'd feel any vibrations in FWD, with no torque to the rear end. So that leaves the rear-diff. I wonder if the rubber mounting-bushings on the rear-diff are failing. With no torque on the rear-end (when in FWD), perhaps the rear-diff can move around a bit, and this may be felt as a 'vibration'. I dunno, this is just my best guess.
For a quick test of the starter: - disconnect the small-gage wire that connects to the starter solenoid-terminal; - connect a wire to the positive battery terminal; and touch the other end of the wire briefly to the starter-solenoid terminal. This will put 12V to the solenoid, and should energize the starter itself. But be aware that the test-wire from the battery will be unfused, and capable of conducting a larger than intended current.
Aside from the same-diameter situation, I would expect that (or at least not-be-surprised if) on-highway driving performance would be affected. I'm thinking that different manufacturers would have their own preferred tread-design and configuration of internal metal/fabric plies. Just how any of this might affect emergency swerving or braking, or cold-weather grip, is an open question. Personally, I wouldn't risk it.
Personally, I would go for the 2010 EJ. That's because I do all my own maintenance, and the EJ is easy to work on. Replacing EJ headgaskets is doable for the DIY-type of owner. Maybe the 2012 FB feels nicer/newer, and drives smoother/quieter; but if something goes wrong, it will be more difficult to work on. And don't get me started about CAN-Bus. I think that both the 2010 EJ and the 2012 FB have CAN-Bus computers and wiring. A nightmare for the DIYer! If you want to get a headache, read this: CAN bus on Wikipedia
