14
Everything posted by forester2002s
I've tried the cardboard in front of the rad. But it was on an old car, and only to counteract a failed thermostat. And I don't think that it will help much in the severe cold of -38. I would replace the thermostat, either with a new OEM, or with a Stant equivalent (the one with a long spring). Someone on this board has a photo of the best thermostat to buy. But I don't envy you working under the car in such cold weather! EDIT: Just noticed that you have 2018. Take it back to the dealer...
- 1 reply
- 1
Try these 2 easy fixes before assuming that it's a head-gasket leak: - Tighten all clamps on the coolant-hoses (if they are adjustable). - Install a new (Subaru OEM) PCV (Positive Crankcase Ventilation) valve. On the EJ25 engine, the head-gasket typically leaks oil and/or coolant to the exterior of the engine. And the favored spot to see this leak is on the left-side (driver's side in US) head, near the rear of the engine and underneath. You have to get underneath the car. You're looking for the joint between the block and the head (not the joint between the head and the rocker-cover, although that might also leak). If the head-gasket is leaking, you'll see oil seeping out of that joint. If the oil-consumption is manageable, replacing the head-gasket is not urgent (but still desirable).
When I learnt to drive, almost 60 years ago, I was taught to slow down using the gears. The theory was that you were always in control, and always in the correct gear to accelerate if need be. After many years of driving manuals, I've changed my habits. I now use the brakes for slowing down, and then shift down when the vehicle-speed has already slowed. It still keeps me in a suitable gear, but it saves clutch-wear. Brakes are easy and cheap to replace. Clutches are time-consuming and expensive to replace. And yes, you may need to know how to drive a manual, if you travel the world.
I can't help with your actual dash, but I can steer you to Amazon.co.uk Recently I was looking for a door window-switch for a friend's car (RHD, but not a Subaru). I could not find the correct RHD part on Amazon.com (the US site, and the biggest selection of items for sale). So on a whim, I searched on Amazon.co.uk instead (the UK has RHD cars). Lo and behold, I found the exact part that I was looking for, and the seller could also ship overseas. It's worth a try. EDIT: I just looked back in my files, and I misled you. It wasn't Amazon.co.uk where I found the RHD part, it was eBay.co.uk , but the same suggestion applies.
This might be the EndWrench article that you refer to. WhBearRep.pdf
- 105 replies
Ms.?, not Mr. Heartless, I believe.
- 9 replies
- 1
- cv axle replacement
- brakes pulsing
(and 3 more)
Tagged with:
I find that the ambient temperature gage is particularly useful as the outside temperature drops to near freezing. If the gage was out by several degrees, especially if it was reading high, the driver could be lulled into a false sense of security (ice wise). If for no other reason, I would expect that Subaru would want the gage to read reasonably accurately.
Take lots of photos before you disconnect anything. As you remove nuts and bolts, put them into containers (old yogurt containers, cut-off plastic bottles, children's snack containers etc). And in each container put a small piece of paper, with a brief description, e.g. 'starter-motor bolts', 'valve-cover bolts' etc. If your engine is dirty/oily, I suggest doing an engine shampoo before you start.
- 105 replies
