11
Everything posted by forester2002s
Here are some measurements that I made on the old rings that I recently replaced (I tend to hoard old parts, just in case...): - These are for a 2002 Forester - Subaru O-ring #73039TA020 cross-section dia. 2.2mm; ID 11.0mm - Subaru O-ring #73039TA040 cross-section dia. 2.2mm; ID 16.8mm These are probably accurate to about +/- 0.1mm. A used a digital-caliper, but it's not easy getting a stable reading on the soft rubber O-rings.
Some Subaru warning lamps can be replaced with Radio Shack (US) mini-bulb #272-1092. Cost a couple of dollars each. The company that took over Radio Shack in Canada, 'The Source', used to also carry these bulbs, but they've gone upmarket and no longer sell small components like bulbs and switches - too bad! I'm not sure which model years use these mini-bulbs, but my 2002 Forester uses them. It's a lot of work to get the combination-display out, but it gives you access to all of the mini-bulbs.
Check the oil level first. Take out the (top) plug; oil level should be up to the bottom of the hole. You can put in your small finger to feel inside the diff if the level is slightly below the hole. Use a turkey-basting squeeze-tool to add more oil. Jack up both rear wheels (parking brake off). You won't be able to 'spin' the wheels, but you should be able to turn each wheel by hand. The other wheel will turn in the opposite direction. There should be no noise or grinding from the rear-diff.
Take photos! If the engine is currently running well, then make marks on the old belt and on the timing notches (use a wax pencil, or child's crayola stick - yellow works well). Then take photos of that setup BEFORE removing the old belt. So when installing the new belt, you can refer to the old photo to check tooth-count etc. Only takes a minute.
I've also had this problem on my EJ251. I always leave the car to cool overnight before checking the oil. Then withdraw and wipe, then reinsert the dipstick. Then withdraw again, and read both sides. The lower reading is the one to use. As the years have gone by on this engine, I check the oil more frequently. At least every 1000km, or every 500km if the level is going down. My engine is the original from 2002, now with a replacement turbo head-gasket. No oil leaks, but it needs about 1-Litre every 3000km.
I love Wikipedia, and I am an occasional contributor. But beware of those compression figures for the EJ16, since there's no knowing where they come from. Wikipedia entries are supposed to be backed-up by references, so that one can trace the info back to the source. In this case there are no links to any credible sources. Those numbers may be correct, but I would add some skepticism to the mix.
The screwdriver method works just fine. There's a hole in the right-side of the engine, about half-way up. Insert the largest flat-blade screwdriver that will fit in the hole, and the blade will then lock the outer (starter) gear-teeth. Works for loosening and tightening the flywheel bolts. No need for a special tool.
