14
Everything posted by forester2002s
I have a set of snow-tires mounted on their own (steel) wheels. I put these on the car for about 4-months each winter. I watch the weather forecasts, and put the snow tires on when the ambient temperature is below about 5C (40F), even if there is no snow. The soft rubber gives good grip on wet roads, deep snow, and hard-packed snow. I never have to worry about getting stuck. These tires are now 8-years old, and I see no signs of the rubber getting hard. Mind you, I keep the car in a garage at night, and keep the snow-tires stored out of sunlight when not on the car. The snow-tires are noisier on pavement, than my summer tires, and I'm usually glad to get them off at the end of the cold weather.
It's probably leaking when you're driving, so the oil-drops get blown away. Try parking with the engine running, with a piece of cardboard underneath. Maybe the leak will show up.
- 3 replies
- legacy
- powe steering
(and 1 more)
Tagged with:
I have taken my rear diff out, and reinstalled it (2002 Forester). Following advice that I read somewhere on this forum, I did not remove the two rear wheel hubs. Instead, I did the following: - Lowered the exhaust by unclipping the 4 rearmost rubber hangers (3 on muffler & 1 forward of the diff). I temporarily supported the weight of the exhaust using a long zip-tie on the rearmost hanger. - Disconnect the drive-shaft at the forward end of the diff (4 bolts) - Then disconnected the diff from the forward steel bracket (4 horiz & 4 vertical bolts) - Disconnected 2 nuts at rear of diff. - Slowly lowered front-end of diff, and pulled the diff forward to extract the two rear studs from the cross-member. (to do this, exhaust needs to be pulled gently towards the floor. - The two, left and right, drive-shafts can then be pulled out of the diff, and supported temporarily. And you're done! It's not too bad a procedure You'll need a trolley-jack, and loads of pieces of timber shims. There's a better write-up somewhere, maybe even a video.
- 7 replies
- differential
- transmission
(and 2 more)
Tagged with:
I've never heard of a 3-piece radiator-hose before. And I've never seen a hose loose enough, and close enough to touch the fan blades. It looks as if you don't have the correct radiator, and someone has rigged-up an extra long hose to teach the radiator. Have you compared this set-up with other similar models, or with a picture in the Factory Service Manual? You definitely need to keep that hose away from the fan. Use some zip-ties or wire to pull the hose away from the fan and towards the engine.
I've had a leak (in my 2002 Forester) with water getting in through one of the mounting bolts for the overhead longitudinal roof-rail. And this leak was hard to find, because the dripping water was hidden behind the interior wall-panels of the car. The leaking water was evident on the trunk-floor, and in the well for the spare-tire. However the water never entered the rear light-assembly. That unit is virtually sealed all around, except where the bulb is fitted.
Clutch-fork: - with no force on the clutch-pedal, can you manually move the top of the clutch-fork to the rear? Should be able to feel some looseness/movement. - with clutch-pedal partially-depressed, can you move the top of the clutch-fork? - with clutch pedal fully-depressed, can you move the top of the clutch-fork? What I'm thinking is the possibility that: - as the clutch-fork moves, the bottom-end of the fork and the throw-out bearing may not be moving as they should; or - the clutch-plate is stuck in the disengaged position, and the fork & bearing are moving but not actually doing anything. I realize that none of this fits with your description that that clutch-pedal feels normal.
You say that the old battery had a "20A drain"; and the new battery has "less than 1A drain". How was this 'drain' measured? I ask, because if the 'drain' was a leakage current via the wiring harness and through the car, then that points to a problem on the car itself, and not necessarily a bad battery. The difference before and after might be because of the intermittent nature of your original starting problem. A large leakage drain, such as the 20A you mention, could be the alternator diodes failing, for instance. If however, the 'drain' is a leakage internal to the battery, then I don't know how this is measured. Other than to disconnect the battery, and to monitor the battery voltage across the terminals. Did the store say how they measured the 'drain' on the battery?
+1 On 'older' cars, the oil-warning lamp is activated by an oil-pressure switch, and means that the oil-pressure has dropped below a safe value. When that light comes on (it sometimes flickers first, before going full on), it means that the engine is NOW being starved of oil. Unless the engine is turned off immediately, damage will result. If it keeps running, the engine is toast. On later cars, there may be actual oil-level sensor, in which case the warning lamp may just be a warning to add oil. But I wouldn't recommend driving any car with an oil light on.
