11
Everything posted by forester2002s
I get the P0420 on my 2002 EJ251 every few months, and then I delete the code. My car normally just does local runs. But once in a while, I go on the freeway at high speed; if it's a hot day, the CEL comes on and it's a P0420 code. So I delete it. Been doing this for years. The engine runs beautifully!
Could be a blocked fuel-filter. It probably needs changing anyway.
- 11 replies
On my 2017 Forester (TR580 CVT), the periodic drain-&-refill only changes about 1/2 of the total CVT fluid. The drain-plug is at the very bottom of the trans. And there's no mention of a CVT filter-change. I wonder if the periodic drain-&-refill is not about refreshing the fluid, but is really about flushing out any wear-debris from the bottom of the case?
I've rigged up a chain-hoist from the garage-rafters. And I use a Load-Leveler from Harbor Freight, similar to this one. But I really like your idea of used long studs in the upper mounting holes, to guide the assembly together. It sounds easy to just line up the engine and trans, and it will all slide together easily. But in practice, it just ain't that easy!
