11
Everything posted by forester2002s
Is the noise the same in different gears? For instance, you are in 4th gear and hearing the noise. What happens if you change to 3rd gear? Or vice-versa. Another way of phrasing this question is to ask: Is the noise related to engine-speed, or road-speed?
- 8 replies
- 2001 forester
- front differential
(and 2 more)
Tagged with:
+1 on it being an internal leak in the brake master-cylinder. You have 2 options: 1. Put new seals in the master cylinder. You may be able to buy a kit for this, or 2. Buy a new master-cylinder. If this was my car, I would go with a new master-cylinder; it's quicker, and more likely to be successful, and only costs a few $$ more. Once it's done, it will probably never fail again in the life of the car.
Get a Gates or Mitsuboshi Timing Belt. Avoid any no-name timing belt, however cheap it is to buy. I would also change the front crank-seal, if there is any oil leakage. And, with the engine out, how about a new clutch-kit (clutch-plate, cover and pilot & throw-out bearings). With the clutch disassembled, check the 'oil-separator plate' (behind the flywheel); it may need resealing, or replacing if it is plastic (but your 2002 Forester may already have the cast-aluminum plate which is less likely to leak). And if there is any oil leakage from the camshaft-covers, then buy a new gasket-kit for the covers. None of this work adds much time, assuming that you already have the engine out. Your Forester should have many years left.
Might be that the timing-belt Tensioner has failed, and allowed the timing-belt to slacken. The noise you heard could be the Tensioner flapping around. Then the timing-belt might have skipped a tooth, and screwed up the valve and spark timing. Take the left-side (looking forward) TB Cover off (3 screws), You'll soon see if the timing-belt is loose.
Yes, the EBay or Amazon kits are fine, but only get a brand-name timing-belt. Such as Gates or Mitsuboshi. If they don't specify the TB brand-name, then don't touch it.
- 5 replies
- 1
- ej25
- timing belt
(and 2 more)
Tagged with:
I too do a water flush after draining the old anti-freeze. But this always leaves some residual water in the cooling system - sometimes quite a lot. So adding 50%/50% premix doesn't work after a water flush. What I do is to calculate how much of the concentrated anti-freeze that I need (knowing the capacity of the cooling system). Then I add that amount of antifreeze to the system. Then I top up with water. Run the car for a day. And then top up with water again, if necessary. That way I end up with the correct antifreeze+water mix.
