14
Everything posted by forester2002s
Give the battery-terminals a little tap with a hammer (or convenient rock). It just may be corrosion at the battery-terminals. One way to check for this is to turn on the headlights just before trying to start the car. If the headlights dim noticeably when you try to start, it may be corroded battery-terminals.
Same thing happened to me. I agree 100% - don't install an unbranded Timing-Belt on your Subaru. I installed an unbranded T-Belt from MizumoAuto, and after 39,000 miles, it had the same transverse cracks at each rib. I asked MizumoAuto to tell me which brand of belt this was. I only wanted to avoid buying another one like that. MizumoAuto failed to reply to my repeated attempts to contact them. See my earlier post (with photo of the cracked belt): http://www.ultimatesubaru.org/forum/topic/154398-timing-belt-best-buy/ One way around this it to buy a cheap kit (with all the idlers and water-pump), and throw away the unbranded belt. Then buy a good belt separately, e.g. Gates or OEM. Or just buy a more expensive kit, with a better belt.
My 2002 came from the factory with the Geolanders. I was happy with the tires, except that they wore out fast. They have a softer rubber than other tires, so give good road-grip, but faster wear. And they were quite good in light snow conditions. But since replacing the Geolanders, I now have 4 snow tires on dedicated rims, which I use from about Feb. to March. They also have a softer rubber composition, so have good grip in colder temperatures and on icy roads. The rest of the year I use 'normal' tires on the stock mag rims. I get tires that are good in rain, and with good wear predictions.
Emily, Yes, 'Left' and 'Right' are always facing forward. But the 'driver's side, and 'passenger's side' depend on whether the car is LHD (Left-Hand Drive) or RHD (Right-Hand Drive). So what might be correct in the Americas, would be the opposite in Britain/Australia/NZ etc, So, lets just call it 'Left-side' and 'Right-side, facing forward.
Change the PCV Valve, and see if that makes a difference.
- 8 replies
- EJ22
- 1993 Subaru
(and 1 more)
Tagged with:
One extra check to make when test-driving: - check that all warning lamps work on the start-up sequence (all warning lamps should work when the ign.key is turned to start, but before the engine actually turns over). For example, the CEL or Oil-pressure lamps might not work. You'll need to be aware of that.
