Everything posted by forester2002s
Check engine light, flashing vs. not
forester2002s replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA flashing CEL can mean that the system is in diagnostic-mode. There should be 2 green connectors under the steering-wheel. These 2 green connectors should be UNPLUGGED for normal driving.
Intermittent smoke
forester2002s replied to iriejedi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChange the PCV Valve, and see if that makes a difference.
High beams 2011 Legacy
On my 2002, I have to push the lever DOWN for it to latch in. The UP position is for 'momentarily' flashing the high-beams.
New Stubborn Valves Won't Seal After Lapping on an EJ25 After a Timing Belt Break
forester2002s replied to dirty_mech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou say that you have the heads ready to reinstall. Have you checked that you have the correct clearances between the valve-stems and the rockers/lifters? These clearances should be very small (see the FSM), but more than zero. Otherwise the valves will not seal completely.
I am looking into getting a cheap fixer upper Subaru,does this one look like a good deal?
One extra check to make when test-driving: - check that all warning lamps work on the start-up sequence (all warning lamps should work when the ign.key is turned to start, but before the engine actually turns over). For example, the CEL or Oil-pressure lamps might not work. You'll need to be aware of that.
2001 outback blowing out rear cam seal
forester2002s replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow is your PCValve? If the PCV is not venting properly, pressure could build up and blow out seals etc.
Which Subrau's are NON-Interference engines?
forester2002s replied to digdug18's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the Mitzumo kit tell you the make of their Timing Belt? If the make is unknown, I wouldn't buy it. Stick with a Subaru OEM or a Gates Timing Belt.
93 impreza
forester2002s replied to jelliff's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo need to be apologetic. You're doing the work yourself, and learning from your mistakes. How many other drivers do that?
96 OBW Instrument Panel Lighting Intermittently Out
forester2002s replied to vasy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould it be a flakey contact in the rheostat for the instrument panel-lights? Try turning the adjustment for the panel-lights (located on the headlamp stalk); that just may clear the problem.
Snow Tire
forester2002s replied to wblocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1 for snow-tires on steel rims. When the first snow-storm of the winter is coming, other people will be lining up at the tire store to get their tires mounted. You'll be able to change wheels yourself in no time.
interchanging fobs?
forester2002s replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you have the fobs, why not just try to reprogram them? cars101.com will tell you how to do this.
2016 Forester - Fob only, open windows if car is not on?
forester2002s replied to xodondum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt'll probably require a little bit of rewiring. On my 2002 Forester, I rewired the windows from the 'Run' circuit, to the 'Acc' circuit. Still need the key in, but don't need the engine running to open the windows. It helps to have proper wiring-diagrams to this kind of mod. EDIT: Just reread the question, and I see that the car doesn’t have a keyed ignition switch. So my comments don't apply.
Transmission interchange
forester2002s replied to pzookey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI recall a post (or two) on this forum, about a year ago. Including a photo of an engine+trans coming out of a car. Try a search on the forum.
97 legacy tail lights won't turn off
forester2002s replied to W&M-Auto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWith the parking switch off, hold it in down with a short piece of sticky electricians' tape. Do that, and it will never happen again!
2001 H6 Outback central noise/thumping on taking off
forester2002s replied to RodA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt could also be failed engine-mounts. When you give the engine some gas, the engine/transmission can physically move around a bit. This can be seen/heard when flooring the gas, either from a start or while on the move. What happens with the car in Drive, and all brakes on, if you give it some gas? Does the engine physically move up?
New 2005 Forester, Fob, Locks, And Other Things
forester2002s replied to Sonicfrog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you tried replacing the batteries in the fob?
1990 EJ22
forester2002s replied to darsdoug's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've said this before, but it's worth repeating: If you're changing a timing-belt, use a wax crayon to mark the old belt, and all gear-pulleys (idlers don't matter), and the timing-marks on the block. Then take photos of this setup. Do all of this BEFORE removing the old belt. Then proceed with installing the new belt.
Too much oil
forester2002s replied to Obwobbles's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru dipsticks are flakey. - Check the oil when the engine has sat for a long while , and is COLD (mornings work well for me. - Take the dipstick out and clean it (don't look at the oil level, it means little). - Insert the dipstick all the way, and withdraw. Check oil level on front-side and on back side. - If you can't get a clear reading, clean and repeat.
Storing Subaru Engine
forester2002s replied to steve56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX'Lower trans stuB'? I think it's a typo, Probably means 'Lower trans stuD'.
Interior side sun-visor for Forester?
forester2002s replied to uniberp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have the same complaint about my 2002 Forester. Also looking for ideas...
low speed wobble
forester2002s replied to mikaleda's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLow speed wobble? Is this a physical wobbling of the steering wheel? Or is it more of an audible rumble?
97 Impreza Headlight Turn Off Unexpectedly
forester2002s replied to palfer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReplace the fuse?
Erratic Revving
Sounds like your clutch may be slipping. Try giving it gas, but apply the brake gently at the same time, to stop the road-speed from increasing. If the engine RPM goes up, then the clutch is slipping, and needs replacing.
Master Clutch Cylinder Problem 05 Forester?
forester2002s replied to fetak24's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnother way to test for a leaking master-cylinder: - Car on level-ground; - All brakes off; - Engine idling; - Clutch-pedal to the floor and hold it there; - Engage 1st gear; - Keep the pedal to the floor, & wait; - Wait some more; - If the car starts to move forward (pedal still to the floor), then the master-cylinder is leaking internally.
New front wheel bearing fail within 5 miles
forester2002s replied to Greenbaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm not familiar with the details of your car. But the axial pre-load on double taper bearings is usually set by tightening the axle nut.
