11
Everything posted by forester2002s
That particular nut is one where I say to myself: "Who designed this terrible arrangement?", and then: "If that person was here with me now, I would give them a piece of my mind". However, there are not many such bad designs on my Subaru; far less than on other cars; the worst IMHO are the 'Detroit' designs, where I swear to myself continually about stupid layouts. For that lower nut, I use a swivel ratcheting/swivel wrench, similar to this one: http://www.sears.com/craftsman-12mm-locking-flex-ratcheting-combination-wrench/p-00942479000P?prdNo=40&blockNo=40&blockType=G40 (I can't recall if that nut is 12mm or 14mm; I've got both of these wrenches) The main problem is that you cannot see the nut, and wrench it simultaneously. You have to get in position to see the nut's location (best place is from above), and imprint that picture in your memory. Then (from underneath) blindly attach the wrench, by feeling with your fingers, and hope that you can get enough torque on the wrench to free the nut. Not the best arrangement, and not easy, but it works.
Replace the coolant hoses: Upper rad-hose; Lower rad-hose; and Bypass hose; plus new hose clamps.
- 2 replies
- head gaskets
- intake m anifold
- (and 5 more)
My car has a secret-switch that does 2 things: - A small red LED-lamp on the console lights up. Mine is a 'solid' light, but a 'flashing' light might be better. - The switch is wired in series with the clutch-pedal-switch (this is a manual transmission), so that depressing the clutch-pedal does not allow the starter to work (as it normally would). I've had something similar in all of my many cars. In the old-days, pre-electronic ignition, the secret-switch was wired in parallel with the ignition contact-points, thus making the distributor not work. I once saw a news item about car thefts. A 'reformed' car thief explained how easy it was to steal cars. The news camera followed the thief as he went from car to car. When he looked into a car and saw a flashing light, he said "I don't know what that light means, and I haven't the time to find out; I'm moving on to the next car".
I have bought most of my new cars through a local Leasing company. How this works is that you sign a leasing- agreement; the leasing period is essentially zero, with immediate delivery and ownership, with full warranty in effect. The Leasing company orders the car from a local Subaru dealership, with whom they have an arrangement. You pay the total up-front (or borrow what you need); my present Subaru was $300 over list + dealer prep & taxes. My local Subaru dealership hates this arrangement (I gave them the option of matching the price but they would not).
Those rattling heat-shield are sure a PIA. The biggest problem is actually locating the source of the rattle. I've tried hose-clamps, with some success. And I've tried stuffing material in between the heat-shields and the actual exhaust-pipes (I use clumps of St.St. pot-scourers, bought cheaply at a dollar-store). This works well for a while, especially once I've found the actual location of the rattle. But it's an ongoing battle (almost 10-years in my case). I've got the rattle cornered somewhat: the noise is only noticeable when cold, and goes completely away once the engine has warmed up. Others have suggested torching the shields off. But I haven't got to that point yet.
Has anyone had any experience with Red-Angel A/C Stop-leak? http://store.gobluedevil.com/a-c-stop-leak-49496 My 2002 Forester has a minor leak somewhere in the A/C system, and I cannot locate it. On a fresh charge, the A/C works OK. But the system pressure gradually diminishes, until after about 24-h, the pressure is so low that the A/C clutch will no longer engage. The slow-leak started a year ago, after I took the engine out to replace the clutch; that required me to pull the A/C compressor out of the way over the side fender; and that caused the A/C hoses to bend sharply. But I've soaped all of the A/C components, and I cannot find the leak. And I've replaced the 2 banjo-bolt O-rings on the compressor itself. I'm looking at the Red-Angel additive, because it is compatible with R12 refrigerant, to which I have already converted. Any recommendations, or otherwise?
OK, I suggest that you test for 12V at the starter solenoid-coil. There should be a single light-gage wire that plugs into the side of the starter - NOT the heavy-gage wire for the starter windings. With the engine not running, unplug that light-gage wire. Test the voltage coming from the wiring harness into that plug, and compare to any engine ground: - depress the clutch-pedal to the floor, and hold it down. - with the ignition-key in OFF, ACC or RUN, voltage should be 0V. - with the ignition-key all the way over to START, voltage should be around 12V. IF SO, then the problem is with the starter. IF NOT, then the problem is 'upstream' of the starter.
I've had a look at the wiring diagrams for a 2002 Forester with Cruise-Control.. It's complicated! But here are some thoughts: There are at least 2 Fuses that can affect the CC: - Fuse No.16 (20A) feeds the 'Stop & Brake Switch', and indirectly the CC. - Fuse No.18 (15A) feeds the 'Ignition' circuits, including the CC-Module. The Black connector for the 'Stop & Brake Switch' ('B65' in the wiring diags.) feeds 4 wires: - #1 Red/Yellow & #4 Yellow/Green have a 'Normally-Closed' contact, and feed the CC-Module (as well as the CC-Switch indicator-lamp). - #2 Blue/Yellow & #3 White/Black have a 'Normally-Open' contact, and feed the Brake-Lights (as well as the CC-Module). The Blue connector for the 'Clutch Switch' ('B107' in the wiring diags.) feed 2 wires: - #1 Black/Red & #2 Blue/Orange have a 'Normally-Closed' contact (#1 goes to Ground; #2 goes to the CC-Module). I suggest that you check these switches for correct operation. I have all the Wiring Diagrams (downloaded years ago as PDF files). But I cannot attach files from my tablet.
Raising wheels off the ground, they will not spin freely. This is because of the rear differential and the viscous couplings in the AWD transmission. This is normal. Is your noise from the rear like a deep-throated rumble? More noticeable at high speeds that at slow speeds? If so, it is probably a rear-wheel bearing failing. Sometimes these can last for years without getting worse. You may be able to detect a slight looseness if you jack-up a wheel, and shake it from side to side and up and down. But that is not a conclusive test. Try this on all four wheels in turn (make sure that the parking brake is off). Do a search on this forum for 'wheel bearing'. There are lots of posts on this subject.
