12
Everything posted by forester2002s
I've had a look at the wiring diagrams for a 2002 Forester with Cruise-Control.. It's complicated! But here are some thoughts: There are at least 2 Fuses that can affect the CC: - Fuse No.16 (20A) feeds the 'Stop & Brake Switch', and indirectly the CC. - Fuse No.18 (15A) feeds the 'Ignition' circuits, including the CC-Module. The Black connector for the 'Stop & Brake Switch' ('B65' in the wiring diags.) feeds 4 wires: - #1 Red/Yellow & #4 Yellow/Green have a 'Normally-Closed' contact, and feed the CC-Module (as well as the CC-Switch indicator-lamp). - #2 Blue/Yellow & #3 White/Black have a 'Normally-Open' contact, and feed the Brake-Lights (as well as the CC-Module). The Blue connector for the 'Clutch Switch' ('B107' in the wiring diags.) feed 2 wires: - #1 Black/Red & #2 Blue/Orange have a 'Normally-Closed' contact (#1 goes to Ground; #2 goes to the CC-Module). I suggest that you check these switches for correct operation. I have all the Wiring Diagrams (downloaded years ago as PDF files). But I cannot attach files from my tablet.
Raising wheels off the ground, they will not spin freely. This is because of the rear differential and the viscous couplings in the AWD transmission. This is normal. Is your noise from the rear like a deep-throated rumble? More noticeable at high speeds that at slow speeds? If so, it is probably a rear-wheel bearing failing. Sometimes these can last for years without getting worse. You may be able to detect a slight looseness if you jack-up a wheel, and shake it from side to side and up and down. But that is not a conclusive test. Try this on all four wheels in turn (make sure that the parking brake is off). Do a search on this forum for 'wheel bearing'. There are lots of posts on this subject.
I once had an annoying slow leak on one tire that was difficult to find. This was probably not what happened to the OP, since that involved two sets of tires. But in my case, what I eventually discovered was a small bar-code label, that was accidently left stuck on to the tire's bead. At first, I couldn't find it. I had no facility to totally submerge the tire in a water bath - that's the best way to find a leak. So I tried hosing the wheel and tire with water, and checking for bubbles. At first nothing; and then about a year later, when I tried the hose again, I noticed a very small bubble forming at the rim-seal. Sure enough, when I deflated the tire, and broke the seal, there was the offending bar-code label (about 1cm x 4cm).
The diff could have been very low on oil. Low enough, that the remaining oil was not wetting the rotating parts. And that would have caused the diff to seize-up and 'explode'. And I can't see on the photo where the oil is actually leaking out; does the crack extend down near to the bottom of the case? And is that where the remaining oil is leaking out? As others have said, these diffs don't usually leak much oil, and can go for years without attention. But yours may be 'the exception that proves the rule'.
- 5 replies
- 1
- differential
- baja
(and 3 more)
Tagged with:
The individual grid lines are arranged electrically in parallel. That means that each grid line has 12V across it. One line can break, and the others can still work. If nothing works, then the break is likely in the feed to all of the grid lines. Check for voltage in the wider vertical feed lines on the left and right. If you have an aftermarket film on the glass, you may still be able to check for voltage by piercing through the film with the sharp end of an electrical probe.
I check my car's fuel-consumption by averaging over 5 fills. I call this a 5-fill moving-average, and I graph this on a spreadsheet. I ignore the fuel-consumption from a single fill. I cannot control how full the tank gets, especially how much fuel gets up into the filler tube. This 5-fill method is best for monitoring long-term changes in fuel consumption, but does also help in the short term too, just not after a single fill.
I am getting ready to replace the head-gaskets on my non-turbo EJ251. I am going to use new turbo-gaskets (#11044AA642), which I think are slightly thicker than the old OEM gaskets. How should I torque the new head-gaskets? - Should I use the 'non-turbo' torques (since this is my engine)? - Or should I use the 'turbo' torques (to match the turbo-gaskets)?
