Everything posted by forester2002s
Forester--vibration at higher speeds
forester2002s replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould also be the rear driveshaft, especially if you get a vibration under load.
5MT Gear Oil
forester2002s replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn my 2002 5MT Forester, I just use 80W90 non-synth, whichever brand is cheapest. Never had a problem with the gearbox.
Failty ECU on '05 Baja, looking for replacement. Any advice?
forester2002s replied to Gevorg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the USM Board!
CEL and Code 24
Sorry, but can't help. However, looking through those 10+ year-old posts, I see that 'nipper' was part of the conversation. Whatever happened to 'nipper'? Seems to have disappeared off the scene.
1998 Forester clutch pedal in "hot" Alaskan weather
forester2002s replied to Ravenwoods's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm not familiar with a 1998. But if it has a hydraulic-actuated clutch, then the slave-cylinder may need replacing (located at the top-rear of the engine-block). If it's cable-actuated, maybe the cable is sticking.
Mild overheating on ez30d. May have found the culprit...thoughts?
True. But the subject line says that this is not an EJ, but an EZ30D. Different engine.
2002 Subaru Forester wheel bearing replacement
forester2002s replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt would be best to start a new post with this engine-related issue.
2000 Legacy L: P0420 Sensor Bank 1?
forester2002s replied to Ravenwoods's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI get the P0420 on my 2002 EJ251 every few months, and then I delete the code. My car normally just does local runs. But once in a while, I go on the freeway at high speed; if it's a hot day, the CEL comes on and it's a P0420 code. So I delete it. Been doing this for years. The engine runs beautifully!
Bouncing off Rev Limiter with CVT...What's Wrong?
forester2002s replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck CVT fluid level?
2003 Legacy passenger window not going up or down- not the switch and not the motor
forester2002s replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBlown fuse?
Which Fuel Pump? 96 Legacy Outback
forester2002s replied to YnotDIY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould be a blocked fuel-filter. It probably needs changing anyway.
Fuel Tank Additive?
I did a google search; there's lot of info available on line, mostly sponsored bu additive sellers. Here's one helpful article: Does gasoline go bad?
Slight overheat after engine-out head work
forester2002s replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs the coolant-level in the overflow reservoir behaving as it should? i.e. is the coolant-level when cold lower than when you stop the hot engine at the destination? And does some coolant then get sucked back into the radiator, as the hot engine cools down to cold (say overnight)?
'95 Impreza manual back from the dead, suggestions, sources, links please
forester2002s replied to myhilo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTake lots of photos (of wires, connectors, hoses, belts etc.) before you disassemble anything.
CVT Maintenance and Service Intervals
forester2002s replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn my 2017 Forester (TR580 CVT), the periodic drain-&-refill only changes about 1/2 of the total CVT fluid. The drain-plug is at the very bottom of the trans. And there's no mention of a CVT filter-change. I wonder if the periodic drain-&-refill is not about refreshing the fluid, but is really about flushing out any wear-debris from the bottom of the case?
Clicking From Front End While Accelerating
forester2002s replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEach time that I have bought a replacement rubber-boot, it came with replacement grease and replacement mounting-bands.
2006 Forester engine noise- rod knock, valvetrain, injector?
forester2002s replied to Stevo F's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSure sounds to me that this is valve-train related (in olden-days, this would have been called 'noisy tappets'): - either incorrect clearances around the cams; - or in need of an oil-change.
EJ20 SOHC with and without cam sensor - what gives?
I've rigged up a chain-hoist from the garage-rafters. And I use a Load-Leveler from Harbor Freight, similar to this one. But I really like your idea of used long studs in the upper mounting holes, to guide the assembly together. It sounds easy to just line up the engine and trans, and it will all slide together easily. But in practice, it just ain't that easy!
That's a great idea. Thanks for the tip.
Hard starting '96 Legacy 2.2L, what could be wrong?
Did this problem occur just after you filled up with fuel? Could be bad gas.
2011 OB water leak, electrical gremlins
Is there water in the spare-wheel well in the back? That might indicate a roof leak near the rear. Or are the front carpets wet? Might be a leak from the windshield.
2014 OB 4 cylinder Check Engine and Brake light flashing
forester2002s replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1
98 Forester Airbag Light on - Code 12?
forester2002s replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLong shot: Does the passenger seat-sensor enable the air-bag circuit? Check those connections under the seat?
forester2002s replied to Stevo F's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould it be a belt-tensioner flopping around?
Need a gasket kit for 2002 EJ251, what's a good choice?
That MLS gasket is intended for turbo engines, but it fit my 2002 EJ251. It seals tight, and the engine runs fine.
