Everything posted by forester2002s
cooling fan question
forester2002s replied to mva5142's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFuzpile raises an interesting point, in that many electrical problems are due to a bad ground. So, have you checked that the ground wire to the A/C fan is good? You can do this with a resistance/continuity tester, or you could run a temporary good ground to the appropriate connector. It's worth a try.
Chilton manual
This DIY H-G write-up (for RS25 engine) may help: http://www.rs25.com/forums/f105/t78972-diy-head-gasket-replacement.html But I don't know if it is exactly applicable to your vehicle.
Timing belt went on my 2.5 legacy
forester2002s replied to swami2806's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis has me worrying about my own 2.5. How many miles on the odometer when this happened?
2000 Outback lazy and hesitation
... fuel filter ...
Can't fill Gas.
forester2002s replied to cfritzin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen you say 'can't fill gas', what exactly are the symptoms? Does the gas nozzle shut off automatically? Or is something else happening?
95 ej22 with siezed / busted cam shaft
BeerGarage! What a great name, and what a great collection of photos!
what oil? ...additives?
forester2002s replied to tricked919's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree that gear and rear-diff oil should be changed periodically. Why don't people do this? I think that Subaru is partly to blame. The recommended maintenance schedule only requires an INSPECTION of the oils every 48,000km, and doesn't actually require any oil REPLACEMENT. When I drain these oils, and see those little metal particles, I'm know that I've done the right thing for my car.
Sticky Clutch
forester2002s replied to nbiehl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere's a (belated) update: - I replaced the Slave Cylinder last summer, and bled the system. - That cured the sticky pedal problem completely. - Now, 9-months & 20,000-km later, I am free of the sticky pedal symptoms. Moral of the story: A sticky clutch pedal is probably due to an ageing slave cylinder.
length of oil dipstick
forester2002s replied to Gentz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI measured the dipstick on my 2002 Forester 2.5 SOHC 5MT. These are the measurements (taken from the underside of the yellow plastic handle, which is where it contacts the top of the filler tube): - 504.8mm to end of dipstick; - 487.8mm to Lower hole; - 466.2mm to Full hole; - 456.0mm to upper notch. The FSM for this model says to add 4.0L (4.2USquarts) of oil after an oil & filter change. When I add that amount, run the engine, leave overnight, then check the oil level, it shows at the Full hole. You can see a photo of the dipstick at
tranny oil frothy on dip stick.
forester2002s replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLet it sit overnight, and then check the oil level again. That might allow the 'froth' to settle, and give you a better reading on the dipstick.
01 forester 2.5 stumble
forester2002s replied to DaveT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd do a search on this board for <hesitation>. There are lots of posts with your same problem. My own solution (2002 Forester 5MT) is to let the car sit for about 10-seconds after start up (not touching the throttle, nor any other electrics), and then to pull away. I find that if I drive off immediately after starting, then I get the low-speed hesitation that you describe.
forester2002s replied to Gentz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat happens if you change the oil & filter, and then add the recommended volume of oil? Where does it show on the dipstick?
Brown Stuff at the Bottom of Overflow Container??
I used one of those cylindrically shaped bottle-brushes to clean inside my coolant overflow tank. It did the trick nicely. Now I can actually see the coolant level through the plastic.
Forester heated mirrors
forester2002s replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA happy ending is always nice! Now you'll be ready for that final blast of winter !!??!!
forester2002s replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have Wiring Diags for my 2002 Forester. Not the same year as yours, but the wiring may be similar. So, on the 2002, the heated side-mirrors DO have a 'Mirror Heater Relay': There is a connector in the bulkhead area, under the dash (the wiring diags show the location on the right-side, but I haven't actually looked for it on my vehicle). The relay appears to just plug in to the connector (and keeps the heater on after the heater button is pressed). The connector is shown as: - Black; - 4-wires: (Black/Yellow, Black, Red/Blue, Black) (actually there may only be 3 wires going to the connector with the two Blacks internally connected). (the Red/Blue is 12V; the Black/Yellow is connected to the 2 side mirror heaters; the Black is grounded). So if you find this connector under the dash, and nothing is plugged in to it, then you may need to buy a relay.
Oil Filter Failure
forester2002s replied to hohieu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree 100%
What does Partial Zero Emission Vehicle mean??
forester2002s replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPartial Zero? That's like being 'a little bit pregnant'.
Added an LED dome light bar!
forester2002s replied to mr.radon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI suspect that the OP didn't want to mess with the 3-position switch on the OE dome-light: - ON - OFF - AUTO
Drain/Fill Diff - Those pesky plugs
forester2002s replied to mr.radon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI guess he wanted your repeat business...
Good news---Bad news
forester2002s replied to starkiller's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis happened to me once (a long time ago, when I was a student). Rather than tow the wreck from my driveway, the insurance company offered to sell it to me. So I bought it, fixed it up (mostly with parts from a junkyard), and drove it again. In those days, that was legal. I don't know about now.
Which gear oil for 5 speed manual?
forester2002s replied to ktdenali's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWise words. I agree.
Sometimes ABS sucks
forester2002s replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI sure hope that someone from Subaru has been reading this thread. And that they take some appropriate action.
Hard Cold Start Issue
forester2002s replied to Stickboy42's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBump. Any answers out there. My son has the same cold-start symptoms on his 2004 Impresa.
so has aney one used the copper head gaskets?
forester2002s replied to AWD TURBO!'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXExactly what I was thinking!
question, how to blow a fuse
forester2002s replied to bheinen74's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAm I missing something? Why not just remove the fuse?
