14
Everything posted by forester2002s
Don't be misled by the look of the tread on 'all-seasons'. They may be good for mud, but they lose grip at low-temperatures. Best to get proper 'snow-tires', which are made with a softer rubber which grips the road better in the cold (below about 5C or 40F). You can do the fingernail test yourself: bury your fingernail into the rubber, and you'll see the difference between the softer snow-tires and the harder all-seasons.
I wonder if this is a fault with the ignition key/switch? Perhaps the switch is staying in the ACC position, instead of turning to OFF? The radio typically is energised when the ignition key is in the ACC position. Are there any other electrical components staying on (when they should be OFF) with the key out? You might test: - windshield wipers; - power windows; - power mirrors; - cigarette lighter; - seat heaters. Some of these might normally be energised with the key at ACC, but should denergise at OFF. BTW, I assume that your radio only stays on (with the key out) when it was already switched on before the key was removed.
Question: Are you saying that you lose 1/4 cup of coolant from the overflow tank EACH TIME that you use the AC? And that it doesn't return to the tank later? If that is the case, then you are actually losing coolant somewhere. However, if the level of coolant returns to normal later, then this is nothing to be concerned about. Please clarify.
Heck NO! Don't discontinue this discussion! I open this thread first, each time I log on. And as for that recent 'black' week, well, I was in withdrawal! From my memory, from a long time ago, in another age, with another car, here is another idea: I once had a hairline crack in a spark-plug's porcelain insulator. It took me ages to debug. I was actually getting a physical misfire (which I don't think that you have). But could a cracked insulator set a misfire code??
Great fix! Talk about ingenuity! I had a similar problem one dark and stormy night... This was old Ford, the car stopped in the middle of nowhere. No fuel was getting through. I couldn't even start it. I tried removing a spark-plug to test for a spark, =OK. Then I pulled out the choke knob (remember those knobs?), and the car started. I drove a long way that night (to see my girlfriend), using the choke-knob as a throttle. The car didn't go very fast, but it got me there! Later, I dismantled the carb, cleaned the plugs, and all was well again.
