11
Everything posted by forester2002s
Years ago (1960s), I recall that some racing cars had water injection to boost performance. At that time (in my pre-Subie youth) I had a 150cc Lambretta scooter. This had a two-stroke engine, and a very simple carburetor. I remember that the engine performed much better in damp weather; it ran much smoother and seemed to have more power than on dry, sunny days. Not a very scientific piece of info, I realize, but the water did seem to help.
Be aware that if you lubricate the threads, you may end up with a much higher stud tension than is intended. This is because lubricated threads make it easier to turn the nut, given a specific torque. Or to put it another way, you may be applying the correct torque, but might be overstressing the studs. In the absence of any instructions to the contrary, it is always best to apply a specified torque to CLEAN and DRY threads. My Subaru Factory Service Manual says: - "Fasteners must be tightened to the specified torque. Do not apply paint, lubricant, rust retardant, or other substances to the surface around bolts, fasteners, etc. Doing so will make it difficult to obtain the correct torque and result in looseness and other problems."
Don't forget that there are 'single-platinum' plugs (with platinum only on the centre-electrode), and 'double-platinum' plugs (with all-platinum electrodes). And that with Subaru's shared firing pattern, a 'single-platinum' plug will theoretically last longer in cylinder #1 than in cylinder #2. Or is it the other way around?
That's certainly the best way to measure rolling circumference, and can be used to compare several tires, PROVIDING all tires are tested the same way. However, if one tire is not on the car (& cannot be mounted on the car), then a tape measure must be used. In that case, the other tire must be taken off the car and measured the same way with a tape measure. To compare circumferences to within a 1/4" (6 mm), both tires must be measured using the same method. Otherwise the differences in measuring methods can easily mask the 1/4" spread.
Disclaimer 1: I know nothing about airbags, so don't take my word for the truth. Disclaimer 2: I don't know anything about the 1996 Legacy. However, this is what the Factory Service Manual for my 2002 Forester, says about DTCs (Diagnotic Trouble Codes): - The long segment (1.2 sec on) indicates a “ten”, - and the short segment (0.3 sec on) indicates a “one”. And so I would say that you are reading DTC 11 and DTC 14. Again, for a 2002 Forester: DTC 11 DIAGNOSIS: Airbag main harness circuit is open, shorted or shorted to ground. Airbag module harness (Driver) circuit is open, shorted or shorted to ground. Roll connector circuit is open, shorted or shorted to ground. Driver’s airbag module is faulty. Airbag control module is faulty. CAUTION: Before diagnosing the airbag system, be sure to turn the ignition switch OFF, disconnect the ground cable from the battery, and wait more than 20 seconds before starting to work. Before replacing the airbag module, roll controller, control module, and sensor, reconnect each part and confirm that the warning light operates properly. When inspecting the airbag main harness, disconnect the driver’s airbag module and passenger’s airbag module connectors for safety reasons. DTC 14 is not listed (in my 2002 Forester FSM).
I would also do an oil & filter change just before the trip (unless this has been done very recently). And I would also check all the tires (including the spare): - remove and replace each wheel (using the jack and wrench that you keep in the trunk); - inspect tread for embedded foreign-objects; - check tire pressures; - if any wheel-shimmy, rebalance tire(s). Replace windscreen wipers? Have a good trip!
Diesel!
forester2002s replied to Olnick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I guess they'll just bore out the 2.0 to make it larger. Did I hear anyone say Headgaskets?
