Everything posted by forester2002s
Switching to Synthetic at 31.5 Km.
If you meant 'kilometres', that's too soon to change your oil:banana: If you mean '1000 x miles', that's another story....
Leaking fuel!!!
forester2002s replied to akjruthies's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWord of caution: I would be very hesitant of driving a car that leaked fuel. Why? In one word: FIRE!
UPDATE (Coolant Fans running Continuously)
Have you tried testing the suspect thermostats? Boil them up in a saucepan of water, and watch them open up... A bit like cooking mussels from the beach.
loud tick in engine
A simple oil change can sometimes clear a stuck lifter. And if the car is new to you, I would suggest an immediate engine-oil + filter change anyway. (And the transmission and rear-axle oils too!)
Interesting info that I learned today
I was vacationing in Tasmania recently, and I was impressed at the number of Subarus there. My (very unscientific) survey suggested that about 1 in 10 cars were Subarus.
Question about Speakers (2003 Outback)
forester2002s replied to Doggcow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProbably around 30 Hz?
Increase Subie milage with water power??
forester2002s replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd like to believe that. However, surely LOWER atmospheric pressure means LESS dense air, and therefore LESS oxygen? A bit like driving up to 10,000ft in Colorado?
forester2002s replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYears ago (1960s), I recall that some racing cars had water injection to boost performance. At that time (in my pre-Subie youth) I had a 150cc Lambretta scooter. This had a two-stroke engine, and a very simple carburetor. I remember that the engine performed much better in damp weather; it ran much smoother and seemed to have more power than on dry, sunny days. Not a very scientific piece of info, I realize, but the water did seem to help.
Looking for a Web site as to Why Wheels may fall off
Are you suggesting that WE (who?) should do it differently than Subaru recommends?
Be aware that if you lubricate the threads, you may end up with a much higher stud tension than is intended. This is because lubricated threads make it easier to turn the nut, given a specific torque. Or to put it another way, you may be applying the correct torque, but might be overstressing the studs. In the absence of any instructions to the contrary, it is always best to apply a specified torque to CLEAN and DRY threads. My Subaru Factory Service Manual says: - "Fasteners must be tightened to the specified torque. Do not apply paint, lubricant, rust retardant, or other substances to the surface around bolts, fasteners, etc. Doing so will make it difficult to obtain the correct torque and result in looseness and other problems."
brake light on????
forester2002s replied to eventoday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you mean the brake 'warning light' on the dashboard? Or do you mean the brake 'lights' at the rear of the car?
Have you seen..........
forester2002s replied to chef_tim's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow is that possible? At 50mm diameter, the rubber seal wouldn't even reach to the sealing surface. Yes. You've every right to be confused...
2003 Outback 4 cyl spark plug brand and type
forester2002s replied to dhewitt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't forget that there are 'single-platinum' plugs (with platinum only on the centre-electrode), and 'double-platinum' plugs (with all-platinum electrodes). And that with Subaru's shared firing pattern, a 'single-platinum' plug will theoretically last longer in cylinder #1 than in cylinder #2. Or is it the other way around?
replacing one tire with 5.5/32nds left
forester2002s replied to dmeucci's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's certainly the best way to measure rolling circumference, and can be used to compare several tires, PROVIDING all tires are tested the same way. However, if one tire is not on the car (& cannot be mounted on the car), then a tape measure must be used. In that case, the other tire must be taken off the car and measured the same way with a tape measure. To compare circumferences to within a 1/4" (6 mm), both tires must be measured using the same method. Otherwise the differences in measuring methods can easily mask the 1/4" spread.
Look at What We just got, 09 Forester!!!
forester2002s replied to one eye's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat is that roof-mounted antenna used for? Radio? Cell-phone? GPS?
Some questions to better my subaru
forester2002s replied to seth3030's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you mean: ...drain, REFILL, drive a few miles and drain again??
Is there a Baja Service manual?
forester2002s replied to darthsoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry Subaru's online site, where you can download Service Manuals (for a fee): http://techinfo.subaru.com/html/ixSearchKwAll.jsp?publication_type=10&model_year=2003&vehicle_line=Baja They list Manuals both for the 2003 Baja and the 2003 Legacy.
Interpreting airbag codes
forester2002s replied to timstiles's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDisclaimer 1: I know nothing about airbags, so don't take my word for the truth. Disclaimer 2: I don't know anything about the 1996 Legacy. However, this is what the Factory Service Manual for my 2002 Forester, says about DTCs (Diagnotic Trouble Codes): - The long segment (1.2 sec on) indicates a “ten”, - and the short segment (0.3 sec on) indicates a “one”. And so I would say that you are reading DTC 11 and DTC 14. Again, for a 2002 Forester: DTC 11 DIAGNOSIS: Airbag main harness circuit is open, shorted or shorted to ground. Airbag module harness (Driver) circuit is open, shorted or shorted to ground. Roll connector circuit is open, shorted or shorted to ground. Driver’s airbag module is faulty. Airbag control module is faulty. CAUTION: Before diagnosing the airbag system, be sure to turn the ignition switch OFF, disconnect the ground cable from the battery, and wait more than 20 seconds before starting to work. Before replacing the airbag module, roll controller, control module, and sensor, reconnect each part and confirm that the warning light operates properly. When inspecting the airbag main harness, disconnect the driver’s airbag module and passenger’s airbag module connectors for safety reasons. DTC 14 is not listed (in my 2002 Forester FSM).
Auto VS. Manuel
forester2002s replied to xr2guy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX...a voice from the dead?
Long haul trip @ 100,000 miles - maintenance suggestions
forester2002s replied to dhewitt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would also do an oil & filter change just before the trip (unless this has been done very recently). And I would also check all the tires (including the spare): - remove and replace each wheel (using the jack and wrench that you keep in the trunk); - inspect tread for embedded foreign-objects; - check tire pressures; - if any wheel-shimmy, rebalance tire(s). Replace windscreen wipers? Have a good trip!
Regreasing Wheel Bearings--worth it?
forester2002s replied to hohieu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI call this: The Zen of Subaru ownership.
Subaru coolant???
I looked at the NABISCO site, and it says to use Crunched-up Oreos mixed in with warm milk. I'll try that at my next coolant change.
Diesel!
forester2002s replied to Olnick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI guess they'll just bore out the 2.0 to make it larger. Did I hear anyone say Headgaskets?
Water in frame rail? '01 OBW.
forester2002s replied to mtbon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe longitudinal roof-rack rails are fastened to the roof with threaded studs. If these get loose (try shaking the rails), water can leak in above the headliner, and might then be channeled down the structure into the sides of the car. Just a thought....
06 Legacy plug questions
forester2002s replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI put single-platinum plugs in my 2002-Forester about 40,000-km ago, before I knew any better. Can I switch them over to 'the other side' and run them there for a while? To even out the wear... a bit like rotating tires? Any thoughts?
