Everything posted by forester2002s
Torque binding/tire size issue. Possible negligence issue against Subaru and its deal
forester2002s replied to edoutback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPlease explain how putting two people in a car changes the circumference of a tire. BTW: 'Circumference' is the distance measured around the outside surface of the rubber tread on a tire.
Gear Oil Questions
forester2002s replied to Bluestone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's a silicone sealant: http://www.threebond.co.jp/en/product/series/sealants/1100list.html
Engine Braking
forester2002s replied to axgutt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy own take on this is that 5000 RPM is too high for engine braking alone. I would use 3rd gear (instead of 2nd), and limit the engine to no more than about 3500 to 4000 RPM, by using occasional pedal braking.
How many miles once the gas light comes on?
forester2002s replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got 40-km (25 miles) out of my 2002 Forester MT5, before the engine started misfiring, and I then refuelled from a portable gas-can.
2001 Forester wiring
What colour is the connector? How many wires connect to each side of the connector? What shape is the connector (rectangular? round? flat?)?
Acetone as a fuel additive
Good for blockages of the human kind too?
Too much oil?
forester2002s replied to mtbe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat should be plenty enough time for the oil level to settle!
What's that Ticking noise!?!
forester2002s replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would echo the suggestion to do an oil change. If it is noisy tappets, then clean oil will often cure this. BTW how many miles since the last oil change? Is the oil black?
EJ25 Head Gasket Failures...why?
- Forester Diesel?
forester2002s replied to Sweet82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDiesel engines for cars have made huge strides in recent years. I recently rented a car in Europe (Spain actually). I didn't realize that it was a diesel at first; it was very quiet, and very smooth. And no noticeable exhaust smell/smoke. It was the 'flat' torque-speed characteristics that made me realize that this was a diesel (high-torque at low revs.). I was very impressed with that engine (BTW it was a Ford). If Subaru can do as well, I may be the in the market for a diesel next time around.- Roof rack on 2001 Forester
My 2002 Forester has different keys for the roof-rack and car. The roof-rack key is a 'Yale'-type (similar to a front-door key), but smaller. There's no way that the car key would even fit into the rack.- 2.5L DOHC Head Gasket Failure *PICS*
forester2002s replied to WAWalker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust to set the record straight: - below the yield point, metals are ELASTIC (i.e. they return to the same shape after the load is removed); - above the yield point, metals are PLASTIC (i.e. they don't return to the same shape after the load is removed).- Door lock problem (not alarm/remote related)
forester2002s replied to dj3stripes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt could be that one of the 'pins' in the cylinder is stuck. First thing, I would try some WD-40 in the lock. Then insert the key and keep wiggling it gently. This might free-up the stuck pin.- Coincidence or problem?
forester2002s replied to rottenhead's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSatellite or UFO? Close encounters of the low-beam kind?- Alias 20035 where R U ?
forester2002s replied to 1Subaru1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, where is he? Here's another post looking for Alias20035: http://www.ultimatesubaru.org/forum/showthread.php?t=9454&highlight=alias- 2 lubricate or not 2 lubri..that is the question
forester2002s replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBut just make sure that the replacement studs and nuts have the correct material and chemical specs. I would want to buy replacement studs from Subaru, just to be sure.- Hesitation shuffle
forester2002s replied to yewman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX...and 'butcher's hook' = 'take a look'.- Hesitation shuffle
forester2002s replied to yewman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd I'll doff my titfer to you!- low speed hesitation problem
This is a common problem with late-model Subies. Have you tried to search on this thread for 'hesitation'? You should get lots of hits.- Air FIlter
forester2002s replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow does the scan gauge and/or ecu actually measure fuel flow?- Torque Wrench use: converting foot pounds to inch pounds
forester2002s replied to jmickelct's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAside from 'slugs' and the various ruminations about force, mass, weight and gravity, the thing to remember is this: If you are only talking (torquing?) about a few inch-lbs, then be CAREFUL not to overdo the tightening; it will be very easy to SHEAR OFF the bolt if you're not careful. 10 inch-lbs is not very much. Sneeze suddenly, and you're in trouble!- I am a tweaker
My 2002 Forester S has peak torque at about 4000 RPM. And so if I floor it at 3000 RPM, it is a bit sluggish. However, change down to a lower gear so that the revs come up, and at 4000 RPM it has a lot more pep. Try it.- Climate control - air conditioning
When I switch to recirc in my 2002 Forester, I am (almost) sure that this is a manual operation, because I can hear and feel a flap(?) move behind the controls. If I'm correct, then this means that I can turn to recirc regardless of the heater settings.- floor mat hook
forester2002s replied to dpoppeli's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 2002 Forester has a single plastic-post at one corner of the driver's mat, and no spikey things on the bottom of the mat. This has never worked well (even when new) to hold the mat in place. The mat rotates itself around counter-clockwise, and bunches up against the wheel-well on the left. The plastic-post wore out after about a year, and would no longer hold the mat in place. So I jury-rigged a large washer and split-pin on the post, to hold the mat in place. But it still rotates as before. This is a silly design. I hope that Subaru have long since reassigned the individual who designed it.- Shouldnt this be clean?
forester2002s replied to keltik's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMemo to self: "Take note of any posts by Blitz". - Forester Diesel?
