11
Everything posted by forester2002s
Why did I buy a Subaru? Near to where I live, there is a steep road with even steeper driveways. Someone had put up a road-sign reading "Rue Subaru". That's when I started noticing the high-percentage of Subarus around. I too live at the end of a steep road, so when I was looking for a new car......
Another consideration is the wear-resistance of the rubber. My 2002 Forester came with original Yokohama Geolander tires. They gripped the road like a cat, but were worn out at 53,000km. My tire shop told me that they were made of relatively soft rubber. A harder rubber tire should last longer, but may not grip the road as well. I replaced the Geolanders with Motomaster SE tires from Canadian Tire. They seem to perform almost as well as the Geolanders, and should (!?) last longer, being made of harder rubber. At the end of the day, I think that it is a bit of a crap shoot. I suspect that driving-style, alignment, and inflation pressure are more important.
My 2002 Forester has the following switches: - Rear Window Defogger: Cancels itself after 15 min, and also when ignition switched off. - Side Mirror & wiper-blade Heater: Only cancels itself when ignition switched off. - Seat Heaters (toggle-switch): Never cancels. Stays on forever, unless switch is turned to off. I have rewired the seat heaters with the addition of a relay and a pushbutton switch. Momentarily pressing the button will latch-in the relay, which allows the seat-heaters to energize. The relay drops out when the ignition is switched off. Ideally, all of these switches should be the same as the Rear Window Defogger, which cancels itself after a set time.
I wonder if this is the same problem as called 'hesitation' by many owners? Do a search on this board for the word 'hesitation', and you'll find lots of suggestions. Many posters have suggested resetting the ECU, to cure hesitation. For myself (2002 Forester), I find that hesitation is most noticeable if I start the engine and then drive off immediately. However if I start the engine, wait about 10-seconds and then drive off, then there is no hesitation.
I wouldn't be too concerned with the observed PSI reading. Unless you bought a precision gauge, I would guess that the accuracy of a mass-produced pressure gauge could be in the order of + or - 20%. So what does 80 psi mean, as opposed to say 60 psi? I don't know. What is more useful, is to watch the position of the gauge over time. As you say, watch it as the engine warms up; and watch it over many miles and over many months or years, to see if the pressure degrades. And also after oil changes. And of course, if the pressure reading goes to zero, STOP THE ENGINE right away!
When I traded my old Dodge 360cu.in V8 gas guzzler in for a Forester, I reused that old locking gas cap from the Dodge (I had it for years; it wasn't OEM; bought it at an auto-part store years ago). The old cap fits the Forester perfectly. And no CELs! So, moral of the story, try a Dodge locking gas cap.
Do a search for 'hesitation'. There have been lots of posts on this board. What I have found (on my 2002 Forester 5MT) is the following: - Start the engine, and drive off immediately = Hesitation at slow speeds. - Start the engine; idle for 10 seconds, then drive off = No hesitation. The other thing that you can try, is to reset the ECU (by disconnecting the battery for 20 mins).
Subaru sell Factory Service Manuals on-line at: http://techinfo.subaru.com/html/ixSearchNkSm.jsp?level=1&model_year=1998&vehicle_line=Impreza You can either pay for specific portions of the manual, or else pay USD35 for a 72-hour access to download any and all of Subaru's technical info. It is all in pdf format. Do a search on this forum to find tips on how to do the download.
No Start
forester2002s replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If you are reading 6.5V on the ignition switch during 'start' (and the starter doesn't turn over), try tracing this voltage back to the battery. In particular, what voltage do you read during 'start': - on the battery clamp? (if only 6.5V, then you may have dirty battery terminals). - on the centre of the battery post? (if only 6.5V, then you have a deceased battery). And you could also check the voltage between the centre of the negative battery post to ground on the engine block (this should be near 0V even when cranking). -
I can't really help either. But, I have a similar problem with my overhead garage-door opener. During the winter, when the garage is colder, the opener works fine. But in the summer months, the door will close on its own, usually just a few seconds after it has been opened. Its been like this for a few years now, and is quite repeatable. Definately temperature-related. I assume that something happens to an internal electronic component, which changes the device's logic. Maybe your remote is doing the same?
I used to have a gas-guzzling Dodge V8. To get through the e-test, I used to increase the idle speed as far as I dared. In my case, the V8 would fail on the idle test, and this helped get it passed. The test centre had a max limit on the idle RPM, I think that it was either 1100 or 1500 RPM. One time I was over the limit, the engine was screaming at idle; the testman let me get away with it, but warned me: 'not the next time...' And one other obvious tip: make sure that the engine is good and hot before going in for the test.
I use the cheapest API-tested oil that I can find (usually at WalMart). I change the oil and filter every 3000km (2000 miles). And I use Fram filters. I know that they have a bad rap. But I've cut several open after changing them, and they all look fine to me. Is there any evidence that Fram filters cause engine failures? In over 40-years of maintaining my own cars, I've never had an oil-related engine problem.
