14
Everything posted by forester2002s
My 2002 Forester has front floor mats (actually not mats, but carpets; perhaps I should call them carpet-mats). The one on the driver's side is attached to a floor-post in the rear left corner. From day one, the carpet decided to exhibit a counter-clockwise tendency, and consequently it rides up towards the left (under the clutch pedal), and folds itself into the left-side wall. Occasionally I shift it back into position, but now the left-side of the mat is bent, and it sticks up in the air! The passenger-side mat has no floor-post, so it just slides forward up towards the bulkhead. Both mats have a pattern of raised nipples on the underside. I think that these are supposed to grip the underlying carpet, preventing the mats from moving, but they don't work.
Two ways around this problem: - Go to a car junk-yard, find the exact same connector, and cut it out of the old car. Then splice it into your car's wiring (solder connections are best IMHO). - Go to an electronics store (Radio Shack?) and find a similar connector with the same number of wires. Then splice that in. Of course, if you think that you'll never to need to disconnect the faulty connector again, then you could just discard it, and make a permanent solder-splice in its place.
Yes, this really works on my 2002 Forester: - Start up, and drive off immediately: Causes engine hesitation and surging. - Start up, idle for a few seconds then drive off: No hesitation, car behaves properly. I have been testing this out for the last few weeks, and it seems to be the answer to my hesitation problems. I use a car ferry every day, and they ask drivers not to idle their engines on the ferry; so I always used to start-up at the last possible moment, and drive off immediately. WRONG thing to do in a Subaru! Try it, you'll like it!
My daughter-in-law's Jeep ran very low on rear-diff oil, and the diff suddenly seized up miles from home. I suspect that there must have been some warning noises, but by that time the damage is done anyway. What can I say? Check the oil-level occasionally! If it's not leaking, you don't have to check it very often.
The Wiring Diagrams for my 2002 Forester also show two fuel-level sensors, wired in series, and with only two wires feeding the signal from the fuel tank to the dash board (and one of those wires is a ground). Each sensor shows as a variable-resistor. As a previous poster suggests, the CPU must use that resistance signal to illuminate the low-fuel lamp. But why can't the CPU illuminate the low-fuel lamp during the lamp-test as part of the crank-cycle at start-up?
When my 2002 Forester was new, I deliberately ran it dry to see what the fuel gauge meant. After the 'low-gas' light came on, I travelled another 40km before the engine started misfiring. And the 'low-gas' light does not come in with all the other test lamps, during the 'crank' cycle. What were the Subaru designers smoking, when they arranged it this way?
Alright, I take back my suggestion about using an old Head-Gasket to wave with. I have just read on CNN that Consumer reports have given top marks to Subaru in 2 categories: - Best 'Fun to Drive' car: Subaru Impreza WRX/STi; - Best 'Small SUV': Subaru Forester. So I suggest that we keep a copy of Consumer Reports in the door-pocket, and wave that at other Subies (and at other cars!)
To check for bad u-joints: Get a large pipe-wrench (one that will open wide enough to fit the outside diameter of the drive-shaft). Grip the drive shaft with the pipe-wrench and try to rotate it first one way then the other (with the transmission in gear, and the of course the handbrake on). If you can see any movement across the u-joints, then the bearings may be shot. You can also do this by hand, trying to rotate the drive-shaft. You may see some movement in the u-joints, but only if they are very loose, and completely shot. Best to put torque on the drive-shaft with a pipe wrench.
