Everything posted by forester2002s
Cursed tailgate latch on 2014 Forester
forester2002s replied to Finfan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe rear hatch has to be properly aligned with the body of the car. If there is any misalignment, the rear striker/latch may not engage fully. When the hatch is closed, the gaps around the perimeter have to be more or less equal (the Factory Service Manual has details). There are 3 adjustment points: - the mounting bolts for each of the 2 upper hinges; - the mounting bolts for the lower striker-bar (hidden under the plastic trim on the sill). I would start with adjusting the lower striker-bar: side-to-side or front-to-back. See what happens.
14" to 15" on 95 legacy
forester2002s replied to Subi Drew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA side effect is the your speedo will no longer read the correct speed. Larger tires will cause a lower speedo reading.
- HELP Intermittent Cutting out / dying 99’ legacy outback
Heater core swap in 2003 Legacy advice wanted
forester2002s replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know that you suspect the heater-core, but... Could it be a hair-line crack in the plastic header of the main radiator? Such a crack is difficult to spot, but will let a fine spray of hot coolant escape into the engine compartment. EDIT: Just seen Texan's (almost simultaneous) post.
SVX crash test
forester2002s replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNasty! Probably wedged the driver's door shut too.
'96 Legacy, what holds the exhaust pipe onto the rear of the cat?
It's called a 'donut'. It's basically a thick gasket, designed to accommodate minor-misalignment of the joint. I think that you can buy a kit that includes the bolts, springs and a donut. EDIT: Found this online; no guarantee that this is the correct donut for your car, but this is probably what you're looking for: Catalytic Converter Gasket (Rear) But you'll need those 'ears' to squeeze the donut and to get a seal.
1999 Subaru Legacy outback
You say: "...we changed water pump thermostat and gasket radiator and hoses..." If the cooling system wasn't bled properly, there might have been air trapped in the system, an 'air-lock'. And that could cause overheating; and it might not manifest itself immediately on short trips around town. But eventually the engine would overheat.
Which early years OBD?
forester2002s replied to bork's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlso Trouble Codes can sometimes mean 2 things: - There's something wrong with the engine/fuel/electrics/exhaust etc., and you may need to replace a part. Or: - One of the sensors is playing up and giving false readings and it's the sensor itself that needs replacing.
fog lights 2017 impreza base 2.0
My 2017 Forester has something like 'directional steering', but it's not much use: - when I turn a corner to the left, the left-side fog-lamp comes on; - when I turn to the right, the right-side fog-lamp come on; - the fog-lamps don't actually swivel at all.
2013 Impreza Starts Then DIES Shortly Afterwards.!
Could be a blocked fuel-filter.
2013 Impreza AC Not Kicking On?
Low refrigerant-pressure?
04 Manual Trans Shift boot attachment?
forester2002s replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think that the boot is clamped/sandwiched under the top trim-cover. Here's a parts diagram that hints at the 'clamping' possibility: https://www.subarupartsdeal.com/parts/subaru-cover-console-box-front~92121sa050.html
Trip prep reminder
Yes, but that means less oxigen available for combustion. Your engine will run rich. Gonna need to clean those plugs...
2010 Legacy Overheating
forester2002s replied to Danimal08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnfortunate spelling mistake? probably = properly ?
Transmission does not engage gears
forester2002s replied to kevsev7k's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMT could have seized from lack of lubrication. Then clutch slips and smokes each time you try to move the car, and the clutch-plate may now be worn down so it slips continually.
forester2002s replied to kevsev7k's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like the clutch is slipping. Could be worn clutch-plate, or throw-out bearing, or clutch-fork. The lack of oil in the MT is puzzling. Involute gears can't run for long without oil, and will self-destruct pretty quickly.
- Proof the longbolt can be extracted, at least in pieces. 08 Forester
Used Subarus on CL
forester2002s replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 2002 Forester EJ251 (which I bought new) gradually seeped oil from the head gaskets. Nothing major, but it did require occasional top-up. Lower left-side was the worst. At 140,000 miles I had the engine out to replace the clutch, and put in MLS HGs at the same time. Since then (about 5-years), the HGs have been tight, not even a hint of seepage.
Airbags worth removing ?
forester2002s replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a garage full of saved 'jewels'. Saved, 'just in case' I might need them. And over the years, my hoard of 'useful stuff' has been invaluable. However, as I've aged, my memory has diminished (slowly, gradually, unstoppable) to the point that I can't recall where my stuff has been stashed, nor even can I always recall what I actually have. I dream that I will bequeath my Aladdin's Cave of jewels to my children and grandchildren. The reality is that they will park a dumpster in the driveway, into which they will toss everything...
Xt hood on na sh forester?
forester2002s replied to Espey16's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShould you be worried? It all depends... How much rain/snow? How much wind? How fast will you be driving? How important is it that you make it to your destination? Are you a worrier? Or are problems like 'water off a duck's back'? Too many variables...
BergerB
forester2002s replied to Bergerb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood question! Could easily be that!
Steering wheel lock won't disengage
forester2002s replied to 1stSubie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSince that first event (about 6-months ago), the problem has not recurred. I do turn my wheels into or out of the curb, when parking on a hill. But I no longer force the steering-wheel over to the side to lock it. In fact I now try not to let the tires actually touch the curb. I suspect that my original problem was that I may have been forcing the right-front tire too hard into the curb to lock it. I think that the elasticity of the rubber sidewall may have acted like a spring, to jam the steering-wheel lock. It hasn't happened again since then.
forester2002s replied to 1stSubie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had a similar problem with my 2017 Forester. It as the keyless feature, with a fob and push-button start. Out of the blue, the steering wheel was locked solid. Like you I tried everything. Eventually I just turned the steering-wheel using more much force than usual, and it suddenly freed itself.
still chasing a shake
If suddenly accelerate, can you hear a 'thump'? And if you suddenly let off the gas, is there a 'thump'? If so, it could be engine or trans mounts.
