Everything posted by forester2002s
no power steering after replacing steering rack
Sounds like it needs a good fluid-flush.
Key works for everything but starting
Program Subaru Keys & Remote
Couple Q’s about EGR and 2000-04 Legacy 2.5
forester2002s replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't know about the Legacy 2.5. But, I have a 2002 Forester 2.5 MT, with the original engine, and it has NO EGR.
Drivers side low beam doesn’t work, new bulb
forester2002s replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXin my experience, when these types of weirdness show up, 9 times out of 10 it is related to a grounding problem.
'08 OB heater temp control
forester2002s replied to opus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh yes, the Zen of Automotive Maintenance.
HELP!! Forester stuck in Drive (auto)
forester2002s replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX'Your item has shipped' I regularly get this notification from Amazon. What they really mean is that a shipping label has been printed, but that they have just discovered that their cupboard is actually bare and that they have no inventory. I feel your pain.
03 ll bean outback temp gauge
forester2002s replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice bit of sleuthing! I'm impressed
Random Misfire
forester2002s replied to Jarsky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1 on the ignition switch being a possibility. It's easy enough to wiggle the key when the misfire occurs, to see if it makes a difference.
2012 Legacy repeat headlamp failure and blowout
forester2002s replied to Daddybob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf two bulbs were wired in series, across a normal 12V supply, each bulb would only be getting 6V. These would be special bulbs. And if they were then converted to the usual parallel arrangement, each would see 12V and would immediately blow. Poof! Much more likely is that you have a grounding problem somewhere in the bulb harness.
forester2002s replied to Daddybob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI doubt that the original Subaru design was for 2 headlamps wired in series. That would be huge safety risk, since both headlights could fail simultaneously while the car is moving.
HELP - DOHC Crank and Cam Seal change and now will not start!
forester2002s replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVacuum leak in the intake? Air-filter cover not sitting tight?
Just another engine parts interchangeability question (EJ251 and ?)
Wikipedia has an online article about Subaru EJ engines. As usual with Wikipedia, completeness or accuracy cannot be guaranteed.
1995 Legacy wagon -- name that part...?
forester2002s replied to bendecker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd why the UP arrow? Is it because the upper mounting-hole is round, but the lower hole is oblong, so not reversible? Perhaps UP is short for Unexplained Puzzle.
2003 forester with a few issues.
forester2002s replied to zyewdall's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru Head Gasket 11044AA642 Subaru Head Gasket 11044AA770
Impreza 95 1.6 FWD - power starts at 4000rpm
forester2002s replied to el_fela's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't know about your particular engine, but typically 4000 rev/min is about 'peak torque'. So you would see some better acceleration at that engine speed. With a manual transmission, 4000 rev/min is good for merging & passing on the highway.
09 Impreza Outback Sport, rear-end shimmy ~40mph
forester2002s replied to 09Imprez's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs there an audible component to the 'shimmy'? Like a 'rumbling' sound? If so, one of the wheel-bearings could be on the way out.
Rear washer hose routing
forester2002s replied to Numbchux's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the spare-tire storage location under the rear cargo-area. On my 2002 Forester, the rear-end of the hose is under the roof-liner, near to the rear-hatch. Mine leaked near there years ago, but I wasn't immediately aware of the leak. The fluid was running down inside of the rear corner-post, and ended up in the spare-tire well.
2011 outback stalling and p2096 code
forester2002s replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXClear the P2096 code. Does it come back immediately? Or does it come back after the stalling problem? Or...?
06 forester starting issue
forester2002s replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMeasure the voltage twice: - First, at the +ve battery-post - Then again at the starter-motor terminal (where the large wire is connected). There shouldn't be much of a voltage diffetence between these 2 readings.
2008 Outback crank no start
forester2002s replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould be the crank-pulley being loose or coming apart, or the timing-belt tensioner being loose? Worth checking these out, if you haven't already.
2000 Forester key fob reprogram to unlock all doors
forester2002s replied to slump's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes your key-fob have fresh batteries? Is the key-fob OEM? or after-market?
Keyless Entry Module Wiring / Fob and Start Issues
forester2002s replied to matt4irish's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow's the car's 12V battery? EDIT: Oh I see that you said that the battery is good.
Transmission Issues - 2002 Forester X 4EAT EJ201
forester2002s replied to shlaggers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry a fresh fuse.
Please help choose snow tires (Outback Onyx XT)
forester2002s replied to jlggomez's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne of the features of snow tires, is that the rubber-compound is softer than on other tires. This gives snow tires better grip on icy surfaces. Do the 'fingernail test' on the rubber tread: stick your thumbnail into the face of the tread; compare different tires. However (there's always a 'however'), soft rubber wears faster than hard rubber. So good snow tires will wear out faster than regular tires.
Grinding sound when coasting
Exhaust heat-shields rattling?
