14
Everything posted by forester2002s
I don't think of Subarus as being low-maintenance. It's more a case of easy- (or at least easier-) maintenance than other makes. Just because other makes don't recommend a lot of maintenance, that doesn't mean that parts won't fail. Yes Subarus can live for a long time, but they do require maintenance, but this is made easier for the do-it-yourselfers.
You were correct in trying that switch on the steering column; that's what it is meant to do (turn off the parking lights). The switch could be faulty. Try prying the switch up and out; then disconnect the switch from its wiring to see if that solves the problem. Otherwise, there could be a problem with the wiring deeper down in a wiring harness.
Long shot: In case the valves are sticking, try an oil+filter change.
- 23 replies
- throttle position sensor
- adjust
(and 2 more)
Tagged with:
History of Subaru CVTs: https://en.wikipedia.org/wiki/List_of_Subaru_transmissions#Continuously_variable
On my 2017 Forester, the Subaru designers have taken this to the extreme: there's no temperature gauge at all!!
I replaced my original 2002 Forester radiator about a year ago. It had a hairline crack in the plastic header near to the upper hose. I had been losing coolant very slowly for several months, but there was no obvious leak to be seen. The coolant loss gradually increased until one day, when I lifted the hood, I could see steam coming from the header. My replacement radiator was a TYC from Amazon. Good price and delivered quickly. One year later and all is fine, with no more coolant loss.
I agree that axles are probably the main problem. But you should check the 3 engine mounts: - 2 lower-mounts between the engine and cross-member; - 1 upper-mount (dog-bone) between engine and fire-wall. If any of these mounts have failed (delaminated rubber?), this could be either the cause of the vibration, or else collateral damage from another source (e.g. axles).
