Sjoubert928
Sjoubert928 last won the day on February 9 2022
Sjoubert928 had the most liked content!
  • Location
    Lee Massachusetts
  • Vehicles
    1992 Subaru Loyale
Recent Profile Visitors
Sjoubert928's Achievements
Newbie
Newbie (1/11)
4
  1. On my list after this - havn't found much in that regard working under the hood and around the car but that means nothing for under the carpets and panels.
  2. This is behind the passenger tail light assembly - it's the pigtail that connects the main harness to the hatch for the wiper motor, plate lights, defroster etc
  3. Yep, although the wagon is originally from Essex County on the coast. Old lady garaged it and used it for bread and milk so I got it at 66K on the odometer last August. Not too bad as a result in terms of rust and corrosion but i'll definitely check those after dealing with this!
  4. Funny you say that - put one bulb back in first thing this morning and that exact pigtail nearly started an electrical fire - issue found! Just lucky I was back there doing that versus driving! Needless to say I had to cut power and cut the self -shorting pigtail after I snuffed it. Got too cooked though to know which wires were going to which to re-wire easy though - is there any online diagrams available or does anyone have a picture from there own car of that rear passenger connection?
  5. Just pulled those to check albeit I don't have new bulbs until the morning - does seem to reduce load on that circuit. Am finding it is putting load onto the Hazard / Clock / Horn fuse and blowing it oddly enough when I open the trunk which triggers the ajar dash light. Just watched the front Markers pulse / get dimmer with the motor running before turning off though with the rear bulbs removed and a new fuse. I definitely got something screwy in the circuit here. Thanks for the tip!
  6. That's my issue, it doesn't matter whether that rocker switch is flicked onto the off or on position on the column - they stay on regardless. I even pulled the switch rocker out and tried manually jumping the contacts to be sure.
  7. First time posting, but have browsed the forum numerous times. I got a 1992 Loyale and - regardless of the parking light switch position - the parking lights stay on. I've tried to do research on it to no avail as everything points to checking that switch. I checked the under dash fuses and even pulled the parking switch off to check to no avail. Is there anything i'm missing or do I have a wiring mystery on my hands?
