subarukris
Everything posted by subarukris
  1. ya i dnt mind haven computer controls as long as i can adjust them to suit mey needs . thanks for the info i will check it out
  2. also to be able to get rid of the computer and run more mechanical would be my preferance that is were its at for me.
  3. well i wanted more control of the timing on the turbo ones i have a propane loyal 1.8l running cams a tooth advanced, i think maybe retarded. any way i needed 45 degrees crank timing at 25psi boost an the thing was one of the crazier 1.8's i have driven only lasted 6000km but i wanted to do it again but blow threw propane or gas but to at least be able to pull some more timing, i was running a low comp turbo pistons as well hoping to stuff more charge in the thing . thanks for the response i appreciate the input
  4. Hi all, i have a lot of old subarus, loyals gl's dl's i want to put 2.5's in them and in the past i have just used the 91 harness from a legacy or what ever cause its dumb and happy to run the motor but i cant get the timeing i want this way, so the other option is to put a distributor on the 2.2 and a carb . but i was hopeing i could find someone that knows about what you need to reprogram the stock computer to give the values i want ? stand alone is one option aswell but expensive and shouldn't you be able to do the same by reprograming stock comp?
  5. i have the same problem 2005 impreza turbo flashing cel runs rough at low rpm seems ok at higher rpm gona check plugs and cop's
