billrigsby
Everything posted by billrigsby
MAY HAVE GOT LUCKY! Pulled one of the covers and belt is intact, tension seems right. Got a code P0340, Camshaft Position Sensor Circuit Malfunction. Don't have a manual, anyone know the diagnostic steps to check this? Or should I just get a new Camshaft Position Sensor and gamble? How much could it cost ???? Bill
I (the kid) has a 92 SVX the rear window washer squirter hose connector has broken. I have plugged it so it does not squirt into the car or trunk. I have not had the car in my garage long enough to remove the wiper assembly. Does anyone know if the squirter is part of the wiper or a seperate part? Bill
I am looking for the MAP sensor on a 94 2.2L Impreza? The Chiltons does not have a diagram, I only know that it has 3 wires 1,2,3 I did find what I think is it but the connector is labeled A,B,C. If this is it the voltage values are way out of range, any idea on cost, do they go bad often? Any one have a photo of this sensor? Bill
I fianlly got around to changing the clutch in the 99 Impreza, I have done a lot of clutches, but I don't remember any that were as easy as this one, even the exhaust nuts/bolts came off BY FINGER once they were loosened. As usual the hardest part was getting the splines lined up and the trans to slide back in. Next i need to do the water pump on the 95 Impreza.... No rest for the wicked :madder: Bill
I like the performance of the 2.2L, has plenty of power but I would really like to get the SVX engine I have in there. Everyone says it won't fit very easily. Do you really have to have the car 3 FEET off the ground to pull a trany, I have never had to get a car thet high, What is the reason for this? Bill
The stock clutch in my 99 Impreza 2.2L has finally started to go . Any opinions on a replacement, Stock, Hi-Perf, Brands, etc. I assume that I will need to just drop the transaxel to replace and not pull the whole engine/trans combo? Don't have a manual for this MY. Looking forward to your opinions Bill
Has any one had any experiance with the following trouble codes, and if so can you offer guidance on the trouble-shooting? Vehicle is a 95 Impreza 2.2 L P0304 Camshaft Position Sensor Circuit Malfunction P0400 Exhaust Gas Recirculation Flow Malfunction P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem I only have the Chilton's which is not a lot of help in cases like this. Any help appreciated, Bill
I keep getting a P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor) code. Has anyone had experiance with this code? I am wondering what a new sensor may cost, does the 1999 Impreza 2.2 have one or two knock sensors, if two which is bank 1? I do not have any manuals for this vehicle (Haynes or Chilton do not have any out yet. To make matters worse I am (MUST) leaving on a 1500 mile trip to Phoenix on Friday, If the sensor/wiring is bad will the vehicle still run or just die somewhere? Need advice quick, Bill
