Gender
Male
Location
Vermont
Interests
snowboarding
Occupation
property rental and web design
Vehicles
2005 Forester, 2003 Baja, 1988 XT6
tappermanor's Achievements
Advanced Member (3/11)
10
Hi Guys, Pulling an engine from an 03 Forester with MT. Getting close.... I'm trying to to take out the torque converter bolts. The FSM and other sources indicate indicate you do this by removing rubber cover under the intake. It also says there are 4 12mm bolts to remove. What I find is 8 (or 9) bolts that are star shape. What gives? I removed the starter and I see normal bolts there? Any help is appreciated. BTW... first time I have pulled an engine if it wasn't obvious. Tap
I bought my baja 2 years ago with 152k on it. I have since put 50k trouble free miles on it. Great car! They seem to hold their value more than legacy wagons or sedans since there are less of them around. A quick check on auto trade shows them from $6 to $15,000. Personally I would stay away from a turbo if I were you. I may be selling mine if you are interested in a high miles, well maintained one at a good price. Tapper
Can be done in one day (6- 10 hours) with you and a helper. You need a good jack to support and help align it. Tap
Yes, that is where I have found them. I just cut of f a rocker panel and there was abunch of insulation material in there
Newbaru-XT strut conversion Q's
tappermanor replied to Racerfab's topic in Old Gen.: 80's GL/DL/XT/Loyales...
bulwnkl is correct. Rear are alot easy to come by. For the fronts you need them from an XT (not XT6 or any other subaru, unless of course you want to modify things) I happen to have a set of fronts from an XT that I will sell cheap. Its all there:mounts, springs and inner struts. They are a little rusty and I don't guaretee the inner strut parts because they have been stored a while. The mounts and spring are fine. $25 ea plus shipping Send me a PM if interested. BTW, getting rid of the air suspension is a good move. It is so problematic. -
Another CT Cook-Out...Anyone up 4 it?
tappermanor replied to Bucky92's topic in Meet n' Greet. Your USMB Welcome Center
Hi Paul, I wish I seen this request before Saturday. I could have had Ho and Melis bring them to you. I have a couple sets. O well Tap -
xt6 ground clearance options?
tappermanor replied to northguy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yaa, too bad the XT / XT6 never had that option
