Everything posted by Dr. RX
WOW, if you can hear rings whistling, your hearing is better then any dog I know. With all that other noise from the exploding gasoline/air mixture, you can pick out the rings whistling, that is truly amazing. Sounds to me that you'd better check out the other possibilities before you start pulling the engine apart to check the rings.
Brooklyn Rallycross pics are posted
Dr. RX replied to edrach's topic in Meet n' Greet. Your USMB Welcome Center
I thought I saw a picture of Matt's Legacy. -
The tranny ratio might be different then the Impreza rear diff. Tranny mount is different. But the big question is WHY?? Just because you have it? It will probably cost you more to make the GL-10 tranny fit into the Impreza then it would just to get another Impreza tranny. I hope you friend is paying for this, he isn't much of a friend if he isn't.
Since it appears to have come with an air bag standard in 93, you my want to check with previous owners (if possible) to see if the bag every deployed. If it did, and they replaced only the airbag, then you will need to replace the turn signal and wiper switch assy on the steering column. That is most likely the problem. Have someone do a "Car Fax" check on the car.
Some of the guys around here have installed EJ22's and EJ25's (the SOHC model) into theEJ18 powered cars and seem very happy with the power, you might try that route before turbocharging the EJ18. If you have a 93, you are in luck because starting in 93 that started only issuing updated for the following years. If you owned a 97, you'd need all the books betwwen 93 and 97 to have the complete manual. I believe there are only two books for the 93 model year. You might have beeter luck finding a CD copy of the manuals then finding the actual book.
Your explaination makes logical sense, but I have never known Subaru to us logic when assigning designations to engines. For example, logically the early WRX engines should be EJ20DET (EJ20, DOHC, Electronic Fuel Injection, Turbocharged) but it is an EJ20G. Low compression 1.8 pistons would have to be custom made, but you could use the exhaust and turbo unit off of an EJ22T (ooppss Logic won out here), but you'd still have to use the 1.8 ECU.
Next NW rallycross June 24th--Scores posted
Is that you Ed Buckner??? -
So, since we haven't heard back from the originator as to what he meant by his EJ18S, we can't make conclusions. You stated a possibility, I stated my interpretation of what that should be, you made a comment, then I asked if you were happy being that way. I have worked in 4 different countries not including the USA (and I don't mean Canada or Mexico), I have taught 'English as a Second Language' to over 40 different nationalities, I speak two other languages besides my own. I probably finished High School before you were born, back in a time when the ability to read and write were taken very seriously. Yes I get very frustrated with the English composition that I see here, but if I had a dollar for every time I didn't post a comment, I'd be a rich person. We, as Americans need to be more respectful of our language, I'm sure that the Japanese or Chinese don't make such mistakes. And you want to talk cultures, take you nick name "nipper", I know of at least two cultures that would be offended by that name. So, if 'drink' is still out there, I would be interested in knowing what you meant by EJ18S and EJ22S. I'm open to new information and maybe you have found something that we all need to know.
I think one of the points that I like to drive home with people who are thinking of doing any type of EA to EJ conversion (or JDM to USDM) is that the mechanical is the easiest part, probably 20% of the job, it is the electrical that is the toughest part
Good question, I really doubt that anyone really knows because most people who want to improve HP are willing to do just about anything. But here are a few things that you can do. 1) Get a cold air system, you'll probably have to custom make this as I doubt any aftermarket vendors will have one for this setup. 2) Increase the boost, get a boost guage and an adjustable boost valve. 3) Get a set of headers and a free flowing exhaust system that includes a better down pipe. All of these will increase HP, but to what extend, I'm not sure.
No cut off date yet, but I was thinking sometime around the 10th of August.
Dont think you can get any chips for the ECU, nor can you get that one flashed. The main differences are the cams, the cam followers and the amount of boost, all other parts are the same. The engine is known as an EJ20G. Yes the downpipe will fit, but from there back is questionable. There is another difference, but this changes regardless of being a GT/WRX or a Legacy/Liberty engine, and that is having a closed or open deck. If your engine has cross hatch marks cast into the block, it is a closed deck. The water and oil passages are different between that head and engine on closed or open deck engines.
Sunday the 25th of June will be the two month mark until the show in August. So far I have 17 people signed up, of those 15 have paid, 2 are suppose to be sending money via snail mail (but I haven't seen it yet). Now is the time to make plans, don't wait until the last second (you might not get the time off you want or need).
Before people reply, maybe they should check out which country the person asking the question is from. The Impreza GT wasn't introduced until 93, the engine is similar, but depending upon the country that car is exported to, it might have the same or more horsepower. For those who may not know, the Impreza GT is what the WRX was called in parts of Europe.
Maybe they do it on Saturday so that people will have another day in the weekend if they need to get something else done, like get their car towed home, or maybe they do it to keep people from racing on the gravel roads around there. -
No charge for spectators. -
Next ORG rallycross event, July 2nd
I'll be in Oregon, but about as far away from Portland as I am right now. I'll be in Sisters, OR. -
hillsboro june 11.....WHAT A BLAST!!!!
Dr. RX replied to 86ruguy's topic in Meet n' Greet. Your USMB Welcome Center
Zap, ask Ken about the second section of the afternoon, is was so dry that you could run on any type of tire, there was a guy who turned in a 1:15 time on street tires, and won the Prepared AWD class, he was driving a 2.5 RS.
