Everything posted by Dr. RX
9 people have pre-registered so far, 7 have pre-paid using PayPal, one is sending a money order, and I'm waiting to hear from one on how they plan to pre-pay.
99 Subaru 2.5RS Transmission Upgrade?
Dr. RX replied to ShadyNluvNit@charter.net's topic in Subaru Retrofitting
Unless you can be sure that they are the same ratio, yes. -
I'm not sure, but I heard that some of the hole in the USDM WRX trannies are threaded, to bolt to an older Impreza, those holes need to be drilled out. -
The two turbos on the Legacy are not for performance (as in more horse power) they are to spread the power over a larger RPM range. One turbo is a low RPM turbo the other is a high RPM turbo, on the older twin turbos there was a flat spot in between, but that was fixed on later models. A larger turbo will increase turbo lag between shifts. The whole thing is to over come the interia of the weight of the turbine and compressor wheels. Some of the newer ceramic and ball bear turbos are larger, yet less weight and spin more freely, but they are also way more expensive.
Next ORG rallycross event, May 7th
Dr. RX replied to edrach's topic in Meet n' Greet. Your USMB Welcome Center
Ken, look again, it also show Zap running in your car. -
So those were your TO scores in teh OBS? Did you run in the afternoon? Next time you and Ken should run what you brung, Ken in the red, you in the green. There might be a surprize at the next one. -
Too late, we already spent it.
I'll bet Ken wishes he could change the TO runs for the scored runs. And who was that driving Zap OBS?? Great times. -
Sorry Jibs, you weren't quick enough, you are the second person to register, someone from NASIOC beat you.
There are a couple of things wrong with that chart, by that chart there were no EJ22 built in 94, it shows a 1600 cc engine built from 80 to 82 and 83 to 87 as an EA81, it would be an EA71, and it shows a 1500 cc built from 85 to 89, the horse power and torque would indicate a 1600 cc engine and the fact that it is in a 2dr would lead me to believe it is in a Hatchback, that would make that an EA71 also. I believe that prior to the XT6 and Justy, the numbers after the letters were the piston diameter in mm's. Although the EA81 and EA82 share the same size pistons, they may have used that 82 to differentiate between the OHV and OHC engines. Prior to 97, the EJ20's had letters at the end to tell what type of engine it was, ie the EJ20 was a DOHC turbocharged engine, after 97 the EJ205 and EJ207 were DOHC turbocharged engines. The engine it the famous 22B was an EJ22G, a DOHC 2200 cc turbocharged engine. The current turbocharged engines are EJ257s.
Gee Noah, mine must be the exception, I don't exactly baby my car, heck just last night I accelerated from a light so fast that the 'G' forces made my wife's back hurt (she had back surgery 5 months ago). I check the oil level everytime before and after an oil change, and it is in the same spot everytime, the engine has over 110,000 miles on it. But back to the problem, have you taken it back to the dealer yet? If not, why not?
Well, I got the PayPal setup today, now we are waiting to Tex to turn on the Registration page, here is the web site if you don't know it already. Check back in a couple of days, it should be up and running. http://www.westcoastsubarushow.com/ Corky
WCSS8 Mug Ordering Time
Dr. RX replied to Subarutex's topic in Meet n' Greet. Your USMB Welcome Center
So, where on the web site does it allow someone to personalize that mugs, it goes straight to PayPal when you click the order link, there should be an intermediate page that allows personalization, then go to the PayPal to order. -
AWWW so that explains the poor turnout, over cast skies, occassional rain, cold and windy. -
EJ22 engine and harness, where do you get them?
Dr. RX replied to Monte's topic in Subaru Retrofitting
Look in wrecking yards, any EJ22 between 90 and 96 is best (non-interfernce engines). -
He's running a 96 JDM WRX STi engine rated at 275hp at the engine, not sure about your WRX but if it is USA stock, that has 227hp? That could be the difference. Great job Dave, with a little practice, you might be able to break into the 13's.
