Everything posted by Dr. RX
Welcome Home Noah Extravaganza!
Dr. RX replied to Subarutex's topic in Meet n' Greet. Your USMB Welcome Center
I won't be there, I promised a guy that I would help him rebuild his car by welding up some of the frame pieces for him, that was yesterday. Well, to make a long story short, he didn't have all the tools we needed (read that as zero) and I had left mine at home thinking he had tool. So I told him that I would bring my tools back today to finish the job. So Noah, have a blast, I'll see you sooner or later now that you are back here in the NW. -
Creative is an understatement. My suggestion would be to get there early. -
If you are getting the engine from a front clip, it should have all the front suspension there, so that part should be easy. I don't know if this will satisfy the requirement for something in writing, but at least you would have basically the same brake as the car the engine came out of.
This whole final drive ratio crap
Dr. RX replied to torxxx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You might be able to get away with different ratios in the front and back on the auto trannies, since they are basically FWD trannies until you push the 4WD button. Even then you might get away with it since the bands in the auto would be more forgiving then the gears in a standard tranny. It could be that the reason why you were changing the tranny was that the person who owned (or someone prior) the car, changed that read diff, not knowing about the tranny having a diff and that the ratios needed to match. All I know is that every EA82 car that I have been under that had an auto tranny has had a 3.70 rear diff. -
Sounds like you need a 5 bolt conversion too.
Well, I just checked the Subaru Parts manual, 85 to 90, it shows a non-LSD 3.70 ratio rear diff for all those years, some of the models shown are turbos, but others are not, so why would a N/A have a 3.70 rear diff? There are 5 different auto trannies from 85 to 90, 1 for 85 & 86, 1 for 87, 1 for 88, 1 for part of 89, and 1 for 89 and 90. The latest Factory Service Manual the I have in the house if for 1986, it shows the auto tranny as having a 3.70 ratio. I will check the other FSMs that I have outside and see if I have one for one on the years in between 87 to 90. -
The EJ20G is the EJ20T, the 'T' is erronious when talking about Subaru engines with the exception of the EA81T, the EA82T, and the EJ22T. JDM engine importers use a generic identification system and for most JDM engines, a 'T' denotes a turbocharged engine. The problem is that for Subarus, the EJ20 series engine has many different ID's for a turbo engine, EJ20G, EJ20K, EJ205, and EJ207, so if you buy from one of the imports, you'll need to know which year the engine is that you are getting. From 1989 to 1996 EJ20G, 97 to 98 EJ20K, 99 to?? EJ205, not sure when the EJ207 came in. Ok, to answer your question, if you are going to use an EJ20G, you will need a tranny from an EJ20G or an EJ22T, both should take the power of the engine. A tranny from a N/A EJ20 may last awhile, but will fail quickly with all the power from the EJ20G.
The only thing that I might add is that if you can car pool it would probably help since parking is limited around his place (all of his cars are taking up his exsisting placing places). -
Japan 4EAT
Dr. RX replied to Eljefe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
To answer your question, it should be a bolt up replacement, but you need to find out what the ratio (front diff) is for the JDM tranny, it might be different in which case you'll also have to change the rear diff. -
I'm sure Dave will back this up, but yes, that is true, but what I'm not certain about is whether or not it needs to be a digital dash or not, I don't think the analog dash has a speed sensor in it.
You might consider something newer then a 93 unless it came from a JDM Legacy. The EJ20G (the correct engine number) in a 93 WRX was the first year, although it looks that same from the outside, internally it is different from the EJ20G that came in the JDM Legacy that year. There were some problems with that engine, and it isn't as reliable as later ones.
If it help, I believe this is the same as our Justy here in the USA. I know nothing about Justys, maybe someone else will now that they can make the connection.
If you can live without an e-brake, you can use Legacy/Impreza parts for the front conversion, but you will have to get XT6 stuff for the rear. A FWD XT6 rear brake system will work, but will require that the center hole be slightly enlarged. I don't know if you guys got the Nissan (Datsun) 200SX, but the rear e-brake on those cars is a close bolt on with some fabrication required.
Converting XT Turbo to 5 lug, Elec P/S, Air Susp
Dr. RX replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There is some confusion on the subject of lower control (suspension) arms. On my RX I used the stock EA82 arms with no problem, others had to use that XT6 arms, it appears that the hole where the bolt goes through at the crossmember is larger on some arms then it is on others. To be on the safe side, use the XT6 arm, we know they have the correct size hole. I don't think the ball joint is different. I'm not sure about the axle question, since I don't know the spline count on a XT6 axle, if it is 25 then it will work, if it is 23 then no it won't. Now that I think about it, I seem to remember that the XT6 has a 25 slpine count, so they will only work with a turbo tranny. I'm glad to see that my pioneering efforts have created a lot of experts, I know there have been several versions of pieces put together to come up with a conversion. If you want to keep the front parking brake, all of these are pretty much a bolt on conversion. If you want to tackle a rear e-brake, that will require a little fabrication skills. -
WCSS8 - Gentlemen/Ladies, Start Your Graphics
Dr. RX replied to P K's topic in Meet n' Greet. Your USMB Welcome Center
Next time you are out by your car, count the number of stars on the emblem, then count the number of stars in our logo. -
West Coast Subaru Show #8 Hat thread
Dr. RX replied to Turbone's topic in Meet n' Greet. Your USMB Welcome Center
I'll beat Zap to this one, START YOUR OWN THREAD!!! -
93 was the first year for the WRX and there were many teething problems, this could be one of them. It almost sounds like a turbo stall, the fix would be to get a turbo off a 95 or 96 WRX. I'm surprised that you would have a 93 in Ireland, I was under the impression the Europe didn't get WRXs until 94, what is the build date on the data plaque, if 9/93 or later you really have a 94.
front to rear..different gear ratio??
Dr. RX replied to mr pink's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If the two diff are different ratios, the transmission and rear diff will bind up. With an automatic, the effect may not be a dramatic as a standard tranny. On slippery surfaces, one set of wheels will spin fasten then the other, on dry pavement, the difference will cause a binding that could eventually cause major damage to one or both. -
To answer your question, no you can not use the Impreza rear brake setup. The 200SX is not a direct bolt up, but from what I hear, it is close.
It would have been more interesting if you had actually done the work yourself.
Seeking rally service crew...
Dr. RX replied to XSNRG's topic in Meet n' Greet. Your USMB Welcome Center
So, do you have things sorted out since I was down there? -
Why pull piston pins first?
Because there is webbing casted into the block by the bearing surfaces that will not allow the piston to pull through that direction. -
wheel spicers on subaru loyale - Q + pic.
Dr. RX replied to moshem74's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Why don't you do a Google search for 'wheel spacers' and see what comes up, usually any place that has spacers for a Subaru should have longer studs too. -
OK, you mean spacer, a spicer is the cross shape piece of the universal joints on a driveline. On wheel spacers you should have at least some threads showing, two would be safe, more is better. Most spacers require either longer studs or bolts. -
New RallyCross regs and classes!
Dr. RX replied to edrach's topic in Meet n' Greet. Your USMB Welcome Center
Oh Oh, looks like I hit a nerve. Just trying to point out the stupidity of the rules.
