Everything posted by Dr. RX
The manual tranny for a turbo is different then the tranny for a N/A. For one thing, it is a hydraulic clutch, and the clutch itself is a pull type, not a push type like the cable release clutches. The clutch pedals and master cyclinder will bolt right up, but you will have fun trying to find the tranny, but a tranny out of a RS or WRX will work too. You probably could get away with a N/A tranny, but if you get too agressive driving, you'll tear that tranny apart, so get use to know how to replace trannies if you go that route.
Figures, the 69th reply would be Zap. Yea, I'm sure about the hood!!!!! But if I run across another one, I'll you'll be the first one I tell.
West Coast Subaru Show 7 Thread (real deal)
Dr. RX replied to ezapar's topic in Meet n' Greet. Your USMB Welcome Center
OK, I'll be looking for it. -
Nope that is a 4/12 pitch. Yea, matching single was a key factor.
Well the roof is on, THANKS ERIC AND NICK, they did a great job getting the roof on in a day. They worked like demons possessed. Here is a current picture.
I bought an EA82T short block from them, no problems yet, that was almost two years ago.
Well the first thing I would do is unplug the air bags, you certainly don't want them going off accidentally. By themself, they create enough damage that most insurance companies will total the car. Since your car is a 98, it would have OBDII, and I don't know of a code 12 for that system, before OBDII the code 12 would work, but the new codes are much more complex in the number format. Check out this link, http://www.rennacs.com/faq.htm it show an error 12 as a airflow meter ot circuit, which has nothing to do with airbags. Look on the link for the question, "What is on the CodeReader™ PRINTOUT?", it shows the code 12 as an example.
It's been awhile since I looked at the decal on mine, but doesn't it tell you what type of oil to use. I used LSD oil in mine, it worked fine. They are correct, the unit itself is sealed, there is no contact between the viscous fluid in the unit and the oil in the case.
You know, I wish I had a buck for eveytime someone asked this question on the board, and got this answer. Show me where there is a diesel Subaru in Japan, if there is, I'll bet that the engine isn't built by Subaru.
WOW, from that map insert, I can see why they call Minnesota the land of 10,000 lakes.
XT turbo into early RX...
Dr. RX replied to quattroPilot's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Are you talking about the turbocharger or the whole engine? If it is the turbocharger, the what Freak said is correct, if it is the whole engine, then what TROGDOR said is correct. -
Passed Sheaving inspection today, now I can wrap the garage to get ready for the siding. Zap is coming over on Monday and we are going to try to get the roofing on (Rob, you busy Monday??). I'm going to get the rest of the roof trim on Saturday and maybe primer the wood on Sunday. I was hoping to have a Garage Warming Party on the 30th, but looks like at least another weekend after that.
This simmering that you call it is only needed if you are aggressive with the car, under normal driving this is not needed. I am an agressive driver, I have a 96 JDM WRX EJ20G powered 96 Impreza, goes like a bat out of hell, I drive it hard, but when I get within about 10 minutes from home, I bring things under control and the rpms down, this allows the engine to cool down as well as the turbocharger. By the time I get home, everything is cool enough to shut it down. I have been driving turbocharged cars since before a lot of you were born, I have never had a single turbo carbon up on me using this technique. swc7916, to answer your question, and this will probably draw flames for the younger set, but I would not give a WRX to anyone who didn't have at least ten years of driving experience. Is the car worth the extra, well that is totally up to you, but I feel if you are asking, it probably isn't. The current WRXs are not like the GC series WRXs from 1993 to 2001. The first JDM WRX had more horsepower (240 versus 227), were lighter and much quicker. I think the closest Subaru, in performance, stock out of the factory, is the STi. But for what you intend this for, replace it with the same type of vehicle you had.
The black RX was a 1989 1/2, it was actually introduced after the start of the 89 model year. I believe it was an early release of the 1990 Loyal RS, which was available in black, but not all RSs were turbocharged, and those that were only has a push button single range 5 speed or an 4 speed auto, the 89 black RXs were true RXs.
Good put, I was thinking the same, I have driven many turbocharged cars, and to me the EA82T has one of the lowest occurrences of turbo lag of those I've driven. I think Subaru did a great job of sizing the turbo to the engine. If everything is right, they are very responsive cars. Corky
Any Legacy with a 2.2 engine would be more reliable then the first series of the 2.5, and probably the second gen 2.5 also. I own a 95 wagon with a 2.2 and auto tranny, I have no fear of getting into it a driving anywhere in the country with it. It is a plus that the current owner had the head rebuilt, but that is another reason not to get the car. The engine is a non-clearence engine, which means when the timing belt breaks, parts bang together, the 2.2 is a clearence engine, if the belt breaks, nothing hits. But I have also known people with 96 Outbacks who have had absolutely no problems what so ever.
It would be nice if our race tracks weren't so far part over here on the west coast, unlike the east coast.
Yea, but he never really got it going. Had to sell it off when he moved up here.
