Everything posted by Dr. RX
CD's with around 300 WCSS 6 Pics
Dr. RX replied to NoahDL88's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Noah, sent you a PM today. -
Nope, the Legacy is a little wider, you'll need an EA82T crossmember. You won't need to change any intake stuff, I found that most of the JDM stuff has the same part numbers and the USA Legacy Turbo stuff, the body harness may even plug into the engine harness if they didn't cut it all to heck like they usually do.
Noah, give my CD to Tex, I'll pick it up from him tomorrow. -
There are several things to consider here. Are you planning to use the EA82 tranny? If so, you will need an adapter for the EJ series engine. One of the board members, Mudrat, has created such an adapter and will soon be making them available for sale. If you plan to use the EJ series tranny, which one will you use? There are two basic types, a cable pull clutch and a hydraulic clutch. The EJ20G (turbo version) usually comes with a hydraulic type, in an EA series car, this requires adapting a different clutch pedal assembly. If you get one out of a N/A EJ series car, it will probably be a cable pull type, with this you can use an EA82 type clutch pedal assembly. For either EJ series tranny you will need to modify the rear section of the tranny mount to get it to fit properly and you'll have to have the drive line shortened 55mm. Now to answer your wiring question, yes you should be able to get the engine to run with an EJ22G (turbo version) wiring harness. I have installed a JDM EJ20G into an EA82 (a RX) before, you will need the EA82T crossmember so that the uppipe will clear the crossmember. Since you are close by, I'd be glad to provide any support if you plan to go ahead with the JDM conversion.
I heard this from several people, "I brought _______ (fill in the blank) to the show for _______ (fill in the blank), but they haven't come and picked it up." Some of these folks made a big effort to make sure that they got the parts to the show for other to pick up. I'll bet they think twice about doing that again.
PayPal is on the way. -
I'll go for one, but more to see how well the camera did, since that will probably be my next camera. -
Official Thank you Ken, Eric and John Thread
Well, what else can I add to what has already been said?????? NOTHING!!!!!! Except, next year is going to be even better!!!! -
Yep, your talking to him. The EJ22 engine Impreza have approximately 52 wires that need to be spliced. Since the manual trannies have hydraulic clutches, you'd have to change the pedal set up anyway, so starting with an auto is a big deal. If you just got your license suspended, maybe this isn't the project for you, this conversion is not for the faint hearted. I can guarantee that if you have trouble getting tickets now, you think that is nothing compared with what will happen if you drive this car.
Just got back from WCSS6, my 96 WRX STi Type R replica (JDM WRX power train) got a little over 24mpg, and the traffic was moving along at 80mph down and back, had a few burst over 100mph. Not bad for 241hp at the engine and 187hp at the wheels.
Not totally sure here, I know that some have had one piece driveline made, other have used the two piece. With the two piece you'll need to attach the center hanger bearing to the undercarage. All EA82s have the same wheel base and use the same drivelines (match to the same type of tranny). I believe that the EA81 based BRATs are close enough to use the drivelines out of the EA82s except for the hanger bearing mod.
Quick answers, tranny side, yep, yep, yep, and yep.
You'll probably need new axles too since the turbo 3.70 tranny has 25 spline stub axles, the N/A 3.90 tranny has 23 spline stub axles. Most people that I have helped put 5 D/R trannies in BRATs use a N/A tranny and we convert a 3.90 open to a LSD.
In case some people have never been to the Hood River Fair Grounds, they are not in Hood River, they are in a little town just south of Hood River call O'Dell, OR. The Fair Grounds is located near the corner of Wy East and Summit Roads in O'Dell. Any of the three exit to Hood River heading south will get you near the grounds, if you get lost, stop anyone in O'Dell, they shoul dknow where the Frir Grounds are. Here is a map, http://corkysrocks.net/WCSS6.jpg
So, if it is a RX, then it has a LSD rear diff (unless someone replaced it) and the tranny will have a 3.70 ratio.
If all goes well, the eastside gang should be rolling into Hood River about 24 hours from the posting of this post.
At 200k the engine is just getting broke in ( ), the 86 sedan that I just sold had over 235k and was running fine when it left.
***Need more power,PICTURE ADDED****
Dr. RX replied to Tim Hoeck's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That depends upon how much money you want to spend. -
Flow, bring it to the show, we'll talk.
OH, OK, I get baja and flow mixed up (on the board only, not in person ). Thanks for the heads up on the spelling, my sister used to live in Milwaukie, OR before moving to Sisters, OR.
Just remember, all cars that go to Japan as scrap have a chance of being reincarnated (pun intended) as a Subaru.
