Everything posted by Dr. RX
If you look closely at the license plate, you will see it is for Queensland Australia, also note which side the steering wheel is on. This is an Australian conversion, they have plenty of the EJ20Gs (turbos) available.
If it were only that simple. The first thing you should notice is that the EA82 turbos make a 90 degree turn to put air into the compressor, on the WRX turbo, it is a straight shot, so some sort of adapter will need to be fabbed, then the up pipe and down pipe need to be fabbed. As long as you keep all the stock hardware, I don't think you'll need the aftermarker ECU or an I/C, but both would be good safety pro-cautions. The whole rotating mass on the T04 is lighter so it will spolls up faster, that also equates to less turbo lag. This also means that you will be pumping a larger compressed mixture into the compustion champer faster, so you will feel quick acceleration. Your HP will be increased, but there is a lot of work.
Yes, I have more pictures, anything in particular you are looking for??
What car are you talking about???
Any other Scots on this USMB forum?
Dr. RX replied to urabus1995's topic in Meet n' Greet. Your USMB Welcome Center
Nope, not from Scotland, but my family tree has roots there. -
Repairing a stripped Spark Plug hole
Dr. RX replied to syphon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think if you bring that piston up to top dead center before you start, you might be able to pull all the metal shavings with a shop vac. -
So what's the skinny on black RX's?
Dr. RX replied to TROGDOR!'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
85 RX Sedans were the first year of RX production. From what I understand, you could get them any color combination, The all white scheme didn't come along until 87. -
It should have had the aero kit too, maybe it got damaged and they never replaced it. But yes these were only built the last half of the 89 model year run. They had special gold trim also. These are the rarest of the RXs. I don't think even Subaru knows how many they made. -
Actually the 2.5 is not simply a bore and stroked 2.2. If memory serves me correctly, one is a closed deck short block and the other is an open deck short block, and therefore the heads would be different. I believe this change came about in 1997, and all the EJ22Ts were build before that. I have an EJ22T and an EJ20G (Turbo engine) that I'm going to try to see if there head swap will work on, both are about the same age, one is a 93 the other is a 92. I have no need for the engine at the moment, so it is not something I'm going to be building soon.
Greetings from a new Member(john)
Hoot man, a fellow Scot. What part of Scotland do you call home. My ancestors were from the highlands, way up north central highlands. -
30" tires/4.44 possibility
Dr. RX replied to bushbasher's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The problem is getting a matched set of pinion and ring gears. I'm sorry if I lead you to believe you couldn't do it, you can do anything you want with enough money. There is a ring and pinion gear manufacturing place up by Paine Field in Everett, WA. I'm sure that if you brought in a tranny pinion gear that they could cut you a ring gear to match it with a 4.444 ratio, as well as a rear ring gear to match the rear pinion with the same ratio. I'll bet you right now that it will cost you more then you car is worth, a lot more. -
WOW, that's rare, a RX with a power sun roof. If the alternator is close to the battery, it is a factory installed A/C, if the A/C pump is close to the battery, it is a dealer installed A/C. The VIN is right for a RX.
Turbo trivia Q
Dr. RX replied to Nug's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Yes Lucky, the EJ20G ( the turbo) was available in Japan in 1989. I installed an 89 JDM Legacy EJ20G into UltimateRX and stated that since both were available in 89 that Subaru could have built that configuration, but they didn't. I just remember, I replace the 89 in UltimateRX with a 92 Legacy EJ20G, so the engine that I'm going to tear down is the 89. -
Turbo trivia Q
I think only turbo poweded EJ series engine have the squirters, the N/A EJs don't. -
A word of caution, Subarus have one of the largest off-set to their wheels of any manufacturer. Any adapter that bolts on to the exsisting hubs is only going to increase that off-set to keep the wheel within the wheel wheel. I know BYB make great products, so I'm not saying anything about them. I just want you to know that if you add adapters to your car, the stock wheels will stick out farther.
Fox, it is so close that it almost ifts, there is just some very minor filing that needs to be done. I would be more of a hassle to swap the caps. The EA series strut cap and the XT6 strut caps are the same.
Turbo trivia Q
I have been told, I haven't seen for myself, that besides the EJ22T, all WRX engines have them. I'm going to be tearing down an EJ20G (Legacy RS engine) for spare parts and will look, but since it is not a WRX version of this engine, I doubt it will have them. -
NO, the EA82 front struts will not work, the front strut is closer to the Legacy/Impreza type struts. The front knuckles are totally different as are the axles. I've done some investigation for 4 to 5 bolt conversion and have found that the Impreza struts, knuckle and axles can used instead of the XT6 stuff, so with a little filing to holes where the strut mounts to the car, the Impreza stuff will work. I know that there were air struts on Legacys, so those should work also. I personally would remove the air struts and replace them with conventional struts.
Yea, I guess Nick is too busy, but at least he could have replied to my e-mails. Last time I checked, I was one of those who volunteered (Dr. RX, aka Corky) and helped pull off last years show. I also know the unbelieveable amount of time that you personally put into the effort of running the club, and I thank you for that. But it might be time for you to move on. If the PNWSEC fades into the sunset, so be it. It is just too hard to try to please all the diverse interests in Subarus in the NW today. You can never please them all, someone will always feel left out. The idea of a Pacific North West club may have been the right thing 6 years ago, but a lot has changed since then. For the Impreza crowd, there is the NW Imprezas Club chapter of the NASIOC, which also includes members with Legacys and other newer models. May be PNWSEC should go to the pre 90 Subaru owners who are not off road enthusists, but if no one steps forward, let it die.
PNWSEC - what is to become of this club???
Dr. RX replied to Subie Gal's topic in Old Gen.: 80's GL/DL/XT/Loyales...
